Question about Frigidaire PLMV169DC Microwave Oven
I have the bracket and filters
Posted on Jan 08, 2008
How do you remove an over the range microwave oven. what screws do you have to remove/
This will depend on where the power source is located, find the cord that is connected. Most are on the top of the unit, some go down the side, there are usually 2-4 screws holding the unit up. The top bar should come out/off, then the screws will be in sight. Ours had 4 inside a bracket. We had to rewire to a new kind, because of the power source on the new unit. So make sure when looking at a new unit that the power cord comes on top, bottom or side like the one that you have now. If you have a cabinet on top of the range/microwave unit that could be where the power plug is installed. The bracket sometimes is screwed to that cabinet. You will have to remove the little bracket/bar by just pulling usually, then most of the rest is just looking to find the screws. Good Luck
Dec 11, 2017 | Microwave Ovens
I have a whirlpool microwave model GH7155XKT. The door cover is cracked badly and I ordered and received the replacement part. I can not figure out how to replace the Choke or Cover
Hi deflcsw,
I see you need a manual on how to replace you Microwave Door.
I checked the Manual does not have info regarding how to replace the Door just the Bulb and the Filters in it see here .
To be able to get information on how to replace the Microwave door you will need to contact Whirlpool 1-800-253-1301, you may need the Model and serial number so they can provide you info about the door replacement over the Phone if the door cannot be replaced by you then they can reffer you to a local center near your address for the replacement to take place or possibly get soemone out to replace it for you.
I hope this helps.
Have a nice day, Thank you for choosing Fixya,
Jul 18, 2011 | Microwave Ovens
Err3 ?
"ERR 3" means that the magnetron units have failed in the microwave. Food will not cook or heat up when the microwave is in use.
The magnetron is the main source of power and heating in a microwave. Magnets work inside a magnetron tube to create the heat and voltage needed to cook items.
Prevention/Solution: Bring the microwave back to the retailer or a repair shop for service. You may also consider purchasing a whole new microwave if the prices are cheap enough.
Good luck.
Apr 22, 2011 | Whirlpool Microwave Ovens
Can you provide guidance on how to install this microwave? Trying to decide if I should pay $120 for the store to install.
Installation of an over the range microwave is not a very difficult task as long as electrical work to provide power is not needed. If no outlet exists then an electrician will be required.
Tools that may be needed for the installation include a cordless drill, drill bit, measuring tape, masking tape, stud finder, razor knife, pencil.
A template is commonly provided for mounting hole locations that need to be drilled in the cabinet. These holes are the top mounts.
An additional template for the wall bracket is normally supplied as well. Here you will need the stud finder, it is important to locate the studs and mount the wall bracket to them.
The wall bracket serves as the bottom mount and aids in the final mounting of the microwave.
Depending on the oven's size and weight a helper may be needed to complete the installation.
Remember to be safe first and seek advice/help with any step you are unsure about.
Good luck.
Jun 27, 2010 | Whirlpool WMH1162XVS Microwave Oven
Trying to remove my Sharp R1830 microwave. We removed the top screws (into the shelf above) and the thumb screws at the bottom of the microwave that clip into the back wall bracket; but the clips seem to...
remove the bottom of micro and filters / with a light look up wher the filter 's are on both sides and you will find a lever that when your pull it .. it will relace from back plate. make sure someone is holding it at this time so it will not fall on range below . ****
Jan 09, 2010 | Sharp R-1480 Microwave Oven
Goes to cooling down and shuts down -Thermador MBY
It sounds like the magnetron is overheating. There can be several causes:
- the vents are blocked
- the outside outlet of the air duct is damaged or has an animal nest in it
- the filters need to be cleaned (if grease filters) or replaced if charcoal filters
- the magnetron is failing
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you don't find yours, or if you want to look at it without disassembling the oven, you can possibly download it here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find links to helpful exploded view diagrams and part ordering help here. I recommend that you bookmark that link to your favorites.
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
To allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, as well as your detailed symptoms.
Dec 12, 2009 | Thermador Microwave Ovens
There are two phillips head screws holding the unit in from the top and a slotted bracket on the wall or cabinet back. Usually you can remove the screws from the cabinet directly above the unit. Support the microwave from the front while removing the screws. CAUTION ! Use two people! While holding the unit level,lift up underneath the rear of the microwave to release it from the slotted bracket in the back and bring the microwave straight out.
May 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Removal of unit from wall bracket
You can download GE installation instructions here.
Then you can see how it went up to help you get it down.
Nov 27, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Can I reuse mounting plate for new microwave?
i always reccomend to my custs that they stay with the same brand for same mounting bracket, dontreally know a way to verify other hten removing hte old micr first and then before purchasing ask to open box to check
Mar 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
New Microwave
Well one would presume you could simply measure the bracket and the microwave, and ask a retailer for the dimensions of units with similar dimensions.
They may also have this bracket and be able to compare the sizes before purchasing your new one.
Not knowing the dimensions of either the bracket itself or the microwave, this would be the only solution i can think of.
Jan 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Frigidaire PLMV169DC Microwave Oven Logo
46 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
