Question about Tatung V27DMBX 27 in. LCD Television
I went on vacation and shut down the tv and now I went to go turn it on and
now it wont turn on at all anyone have any ideas
  • 3 more comments
  • richnjess Apr 20, 2008
    One day our (2 yr. old) Tatung television would not turn on. The red led light will not turn on either.
    We did plug in our Wii system into it, could this be related to the problem?
  • pokie79 May 07, 2008
    I have the same issue, I took my Television to a repair shop and they stated the power supply/control board was bad. He also stated that getting parts fromm Tatung is slim to none. I am in the process of trying to order parts. I had to call 888-482-8864 to get a case number and them call 915-772-5991 ext 1653.
  • punkwonkers May 13, 2008
    tangtung /ilo 27 inch just shut down will not come back on red light just glows will not go to green. also walmart deleted al info from the databases?????????????
  • hitsmanj80 Jul 19, 2008
    My tv is an ILO from Walmart, but it is the exact same as the Tatung. It won't power on. When unplugged for some time and then plugged back in the LED will flash momentarily and then go back off, which looks like a power supply problem. I found this manual:http://pettersservice.com/polaroid/docs/...
    And have also contacted TMX (same as pokie79) to get the power supply, which they list for $75. Will post results when they happen.
  • Anonymous Dec 26, 2008
    Went completely dead nothing happens when you go to turn it on. No power completely.
I had the same problem. One repair shop said that they could not get parts. With $50 down the drain I took it to another guy who had the power board replaced in one week (for $200). So it can be done.
Posted on Jun 06, 2008
Avc on keyboard not function
It is possible that the set has been hit by a small power surge and if you unplug it from the wall for 40Min. it should reset back to normal , and your problem will be fix.
Apr 11, 2012 | Tatung V27DMBX 27 in. LCD Television
MODEL V27DMBX- NO POWER, WON'T TURN ON.
good day sir
the problem of your TV is on the power supply
I teach you some D.I.Y.tips and troubleshooting for your problem
I give it to you step by step
first remove the cover of your TV by unscrew it at the back
secondly after that the power supply reveal it is the one that have a ac input from your ac cord or supply
thirdly,check your fuse if busted,replace fuse if busted and also check the regulator transistor if shorted then replace also
after that,also looking for bulging top capacitor/leak replace it in same type and rating voltage/microfarad
and finally after same troubleshooting..test it by power it on again
thank you
Apr 02, 2011 | Tatung V27DMBX 27 in. LCD Television
How do you take off the back panel for a tatung 27 in? I have taken out all the screws and seem to have resistance any help would be great.
Did you remove the stand? It can be very difficult sometime due to the plastic fingers that snap the TV together. Use the thin flat blade screw driver to separate the rear cover, make sure to have the front laying down on a soft surface, starting at the bottom edge first and work your way around.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c rating such as PANASONIC FM or FC series.
Dec 04, 2010 | Tatung V27DMBX 27 in. LCD Television
My Tatung flat screen cannot be put on channel 3, and the remote is dead. Channel 3 is required to access cable
Try using channel 4 instead. There should be a switch on the cable box to switch it to channel 4 instead.
Nov 10, 2010 | Tatung V27DMBX 27 in. LCD Television
I need the remote control for this tv,How do I get one ?
I have two different models of the Tatung V27DMBX at remotes.com. Check if one of these is the one you need. http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=V27DMBX&uuid=12791619149380 (They have both the original remote and a replacement remote that has most of the features.)
I hope this helps.
Jul 15, 2010 | Tatung V27DMBX 27 in. LCD Television
Screen is nothing but static, BUT...
cheak your cables what inopuut is snowy all or just tv does dvd work
Feb 03, 2008 | Tatung V27DMBX 27 in. LCD Television
TATUNG 30" LCD HDTV MONITOR WILL NOT TURN ON
I found a replacement Scheda power module at you guessed it, not at Toys R Us but rather at www.tvmodulesrus.com for $79. The same module is used in several LCDs, including our PowerSpec 30" LCD sold at Micro Center. It is listed under several numbers at TV Modules R US:
P/N: 6693006610
Model: HOAU242001(A)
Scheda Inverter PWB-0656-03
Nov 28, 2007 | Tatung V30DMTT 29.6 in. LCD Television
Ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Jul 31, 2007 | iLO V27DMBX Television
Tivo Remote
I found this usefull tip on the Tivo website. Here is the link for the page. I hope it works for you. http://customersupport.tivo.com/LaunchContent.aspx?cid=a8722f21-6f9a-42ec-8626-02dcef837619&anchor=undefined
Feb 23, 2007 | iLO V27DMBX Television
Tatung V27DMBX 27 in. LCD Television Logo
399 people viewed this question
Top Tatung Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Tatung Televison and Video Expert? Answer questions, earn points and help others
