this could be caused by a bad diaphram in the oil pump but it is probably happening because the oil ports in the bar are plugged with sawdust. Take the bar off and clean out the oil ports and with the bar off run the saw and see if oil is coming out of the hole that matches up to the port in the bar. If not then you will have to replace the oil pump. Hope this helps you.
I Have been looking at backpack leaf blowers as we have a 1/2 acre lot that has , at this time of...
(More)
I Have been looking at backpack leaf blowers as we have a 1/2 acre lot that has , at this time of year especially, a lot of Oak leaves and pine needles. We have been using a Echo 201 hand held blower for several years, but need something stronger. I was looking at backpacks at my local Home Depot and was fascinated by the Ryobi Model 971743 as it has a
lithium battery electric start, which would be simple enough for my wife to operate. She doesn't do well with pull starts. I have no experience or knowledge of Ryobi quality and dependability.
mcCulloch bl150 will not run once full choke is removed I have replaced fuel lines and primer...
(More)
mcCulloch bl150 will not run once full choke is removed I have replaced fuel lines and primer blister and blew fuel tank and carburettor with air but once I start it it will run for about 5 seconds then I take the choke off full it will stop regards KEN
I have a homelite backpack leaf blower I can adjust the idle speed but once i give it gas it boggs...
(More)
I have a homelite backpack leaf blower I can adjust the idle speed but once i give it gas it boggs down and stalls
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
