Question about Viking DMOR205SS Microwave Oven
Scratches on microwave door
I was trying to clean some grease spots on microwave door and ended up scratching it with a cleaning sponge. How can I remove the scratches or is there any way to replace just the door of the microwave?
We have an over the range GE microwave and my wife was cooking some pasta on the stove and used the vent fan on the microwave to dissipate the steam and when we were done eating she noticed that the steam from the pasta had gotten in between the glass on the microwave door, how can we get rid of this any ideas.
Posted on May 27, 2009
  • Viking Master
  • 9,098 Answers
Replacing the door is a bit of a job and I'd bet that Viking parts will be very pricey. Even though these are made by Sharp, you'd have to order door parts from Viking.
You may be able to buff it out with jeweler's rouge / paste or toothpaste on a cotton cloth or even a microfiber polishing cloth.
I advise my customers to never use Windex (ammonia-based) or anything other than a soft cloth to clean the plastic parts.
Please reply back if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 27, 2008
    New Friend:
I did the same thing--scratched the microwave door cleaning with the rough side of a sponge-----tried some car scratch stuff, but that didn't do any good. I put some left over static-cling window film all around the microwave door and that did the trick---can still wipe clean and easily removed if need be without any further harm---(be sure to use static-cling film.
Posted on Mar 31, 2013
How do I clean the inside of my Mile microwave
Almost any non-abrasive cleaner would be okay. Use something that can cut grease and I would also recommend using a sponge or wash cloth and nothing abrasive so that you do not scratch any of the paint.
Mar 05, 2015 | Microwave Ovens
I have a Miele h5080bm microwave oven. How can I clean the grease of the roof and sides of the microwave?
You can put a microwave safe bowl of water in the oven and heat it to boiling, stop the microwave, then leave the bowl of water in the oven for about 10 to 15 minutes. The steam will loosen the dirt and grease and then it can be wiped with a damp sponge. More stubborn grease my need dish soap on the sponge and a little more elbow grease. Rinse it well with a clean sponge or dish cloth and warm water.
Feb 15, 2013 | Microwave Ovens
I've got a badly scratched touchpad membrance from abrasive sponge - lesson learned the hard way. Anyways, how do I replace the touch pad membrane on a Kenmore Microwave Model # 721.80049700? I&
I am not familiar with that specific model but typically touch pads either come as an assembly or as just the membrane that has a peel off paper on the back that covers a sticky layer that sticks onto the metal frame inside your unit. If that is the case, you have to remove the old touch pad and take a screw driver or a knife and start at one end and lift it off of the frame, once peeled off, clean the metal frame with laquer thinner to remove the old adhesive, make sure it is dried completely and then take off the protective paper of the new pad and stick it to the frame. If it is a plastic frame you CANNOT use a solvent like laquer thinner as it will melt the plastic frame and destroy it. On those I tend to just drag a razor blade across the surface until I feel it is clean enough to mount the new one. You could use alcohol to clean it. Or possibly mineral spirits. You jsut want it to be perfectly clean and grease free
Oct 02, 2017 | Microwave Ovens
Is this a self cleaning oven? If so how do you set it to self clean?
Self-cleaning microwave oven?
Loosen up gunk and grease splattered inside your microwave by following this simple tip. Fill a pyrex measuring cup or other microwave safe bowl with one cup water and put in microwave on high for three minutes. This should bring the water to a boil. Let it set in microwave for several minutes with the door closed.
Then, wet a sponge or soft rag with a tablespoon of vinegar. If you need a degreaser, add a few drops of dishwashing liquid to it. Wipe microwave clean with the rag or sponge. The microwave will practically clean itself. Now that was easy!
Jun 03, 2011 | Microwave Ovens
I have a scratch on the top of my ceramic stovetop. How can I repair it?
Instructions for repairing scratches on ceramic cooktop
Things You'll Need:
  • Nonabrasive cleaner
  • Dishwashing liquid
  • Cloth
  • Razor scraper
  • Ceramic crème
  • Sponge or cloth(s)
  1. 1 Clean the cooktop with a nonabrasive cleaner, such as a glass cleaner or warm water mixed with a few drops of dishwashing liquid. Wipe with a clean, soft cloth.
  2. 2 Use your fingernail or the flat edge of a razor scraper to remove any raised surfaces on the scratch.
  3. 3 Apply a ceramic repair crème, available at most hardware or home repair stores, to the scratched area. Work in gently with a soft cloth or sponge.
  4. 4 Allow the crème to sit for 15 to 20 minutes. Wipe away with a clean, damp, soft cloth.
  5. 5 Repeat as necessary until the scratch is no longer visible.
Nov 10, 2010 | KitchenAid Microwave Ovens
I have a GE spacemaker. It releases electric volts when is turned on . Needs to be changed or can be repaired?
Do you mean "sparks" inside the oven cavity when it is operating ?
If so, check for grease spots on the wave guide cover or scratches on the oven liner. Scratches can be touched up with touch up paint and wave guide cover`s can be replaced.
Hope that help`s, good luck.
macmarkus :)
Feb 10, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave is scratched
You will need the following:
Polishing compound, jeweler's rouge or whitening toothpaste
Electric buffer
Lamb's wool buffing pad
2 ounces of ammonia
2 quarts of water
Rubber gloves
Safety goggles
Lint-free paper towels or cloth
Step 1:
Apply polishing or jeweler's rouge to a lambs wool buffing pad. You can either buff the scratch by hand using a circular motion or with an electric buffer on medium speed.
Step 2:
Wash the polishing compound, jeweler's rouge or whitening toothpaste off from time to time in order to check on the progress of the scratch removal.
Step 3:
Mix two ounces of ammonia with two quarts of water. You may want to be sure to hold your nose closed during this process! Also, always wear rubber gloves and safety goggles when working with ammonia.
Step 4:
Clean the glass surface with the ammonia water with a clean soft sponge.
Step 5:
Dry the glass with a lint free towel. If the scratches are not completely gone, they should at least be less apparent. If there is no significant difference, consider contacting a glass company to replace or rebuff the glass.
Jul 27, 2009 | Frigidaire FMV156DC Microwave Oven
Front of microwave door scratched
3M 7447 pads get at auto parts store or more aggressive 180 grit sandpaper going with the grain of course. For daily cleaning use DeBruce Polish, it is non-toxic and odorless. DeBruce polish is also non-abrasive, also use DeBruce Polish on glass/ceramic cook tops. We get DeBruce Polish at debrucepolish.com
Feb 27, 2009 | Frigidaire FMV156DC Microwave Oven
Microwave oven door - interior scratch
inside the microwaveoven shouldnot put tape or other adhesive materials, replace the door immidiatly..
Sep 24, 2007 | Microwave Ovens
Microwave door has burn spots on the glass of the door...
The brown spots are usually grease / smoke deposits. Usually there are indeed two sheets of glass in the door. If the grease is not arcing or smoking, and the metal screen / mesh (that blocks microwave leakage) is not damaged, then it's likely better left alone. It might be useful to boil a few cups of water with a little vinegar inside the microwave to help dissolve the deposits. In case you want to take it apart, I have attached a photo from a similar model that illustrates disassembly of the door. It is not necessary or advisable to remove the door or hinges when disassembling the door.
Jun 25, 2007 | Goldstar MV-1501 Microwave Oven
Viking DMOR205SS Microwave Oven Logo
3,187 people viewed this question
Top Viking Microwave Ovens Experts
William Miller
William Miller
Colin Stickland
Colin Stickland
Craig Butler
Craig Butler
Are you a Viking Microwave Oven Expert? Answer questions, earn points and help others
