Question about Kingston 1 Bay Data Express DE110 USB 2.0 Internal Drive Case
Kingston usb 1GB
My 1GB flash USB can no longer be used as it apears as a 256GB and can't be formated as the volume is too large.
Thanks,
Ben
  • Anonymous Apr 14, 2008
    dear sir/ madam,
    I m biswjat nath bought a 1gb pendrive few months before from delhi but now its not working not showing anything when i m inserting in the usb drive right now i m in bangalore so pls any body can solve my problem then pls mail me on biswajitnath24@yahoo.co.in.
    Regards,
    Biswajit
  • Anonymous May 05, 2008
    i cannot formatting my usb
  • Kingston Master
  • 27,725 Answers
Usb chkdsk utility
Click start control panel Administrative tools Computer Management Disk Management
right click on your drive select properties click tools you should see click check now click start two boxes
Automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start then after its finished return and tick the other box you should not do anything while the chkdsk utility is in progress any input may damage this drive.
You might get best results ticking in one box the returning after it has finished then ticking the other box.
It might take some time depending on the size of your disk but be patient.
then you restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
you might have to alternate doing this repeatedly until you find the sequence to get the problem is resolved
click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system
Remove write protection to format
You have to be the computers Administrator to change any values on any Hard Drive on your computer.
Click start control panel user accounts on the users tab click the name of the computer Administrator you must have full control.
Click start click to open on my computer you should see your Usb drive E: or something
right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions.
Make sure all 3 boxes are ticked full control change and read in windows 7.
Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP.
Click start right click on my computer select open
Right click the icon of your Usb Drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
Click start click on my computer to open you should see your drive
right click then select format
another way
Click start control panel administrative tools computer management disk management
Right click on your usb drive select format.
If you need more help with this post a reply
Posted on Nov 12, 2013
How do i format the kingston datatraveler 310 256 gb to ntfs file system
Hello insert the drive in the usb port.
When you see the drive in the control panel, right click on it and choose format.
Select NTFS in the selection box, and mark quick format and click start.
This could take a while.
You just have to save ALL the previous saved files, before you format, because the files will be lost, when the the drive is formatet.
Good luck
Mar 04, 2013 | Kingston DataTraveler 310 DT310/256GB...
How to format
click start click on my computer you should see your usb drive
another way is to control panel administrative tools computer management disk management right click on your drive select format
if you need more help with this post a reply
Hope this helps
Nov 11, 2012 | Kingston Genuine Dt310 256gb Usb Flash...
Uploading to kingston data traveller 64GB corrupts my files
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Dec 27, 2009 | Kingston Technologies 512MB DataTraveler I...
Micro sd card deleting problem
Dear,
You need not to think about that because such amount of space used by the Drive for its file system.
Regards,
Rakesh Kumar
Mar 31, 2009 | Kingston 1GB Secure Digital Memory Card
Formating??
Hi j_perez022,
Insert the memory card into a reader on your computer. Open My Computer. Right-click on the drive letter for the memory card. Select Format from the menu. Click on Start in the Format window. Proceed from there.
Kingston Tech Support
Feb 24, 2009 | Kingston 1GB Secure Digital Memory Card
Not able to copy more than 1GB into 2GB Kingston SD card
Hi 1123sun,
Copy your files off the card. Then Format the card and select FAT32 file system. After the format is done try the card again and see if you can copy more files to it.
Feb 18, 2009 | Kingston 2GB Secure Digital Memory Card
Unable to format 64 gb kingston pen drive
These are actually ccore flash drives, shipped with the name "Kingston". YOU CAN FORMAT ANY ZIP DRIVE WITH "HP USB DISK STORAGE FORMAT TOOL". Trust me, it really does the needful. I had the same problem earlier =)
Feb 12, 2009 | Computers & Internet
How to format a pen drive?
Try HP formatting tool with administrator previliages in vista
Nov 29, 2008 | Kingston Technologies 512MB DataTraveler I...
Kingston usb 1GB
Have not encountered a problem like this before, but you can try booting from your Windows CD if you have Windows... While your USB is inserted in the USB port. After entering the setup continue until you find your partitions where your drives is listed, you will notice your USB Drive will also be listed there. Select your USB Drive, and simply Delete it and recreate the drive. After that, just reboot your PC, and do not continue the windows setup.... Boot up Normally, and see if it works.
Hope it helps
May 05, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Computers & Internet Logo
74 people viewed this question
Top Kingston Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
