Question about Sony KP-57WS500 57" Rear Projection Television
Blue screen flashes and the tv shuts off
I have a Sony 57" KP-57WS500 rear projection tv. The set is flashing a blue screen and then shuts off. What is the problem and it is worth fixing it?
  • Sony Master
  • 8,617 Answers
You will need a service manual you can get one here it could be the tube, video or numerous things. Your service manual is available at the following link. Plus online support
http://servicemanuals.vstore.ca/
Posted on Jan 10, 2008
If you follow the info from this website, you will be able to fix your TV.
Use at your own risk. Please be very careful when working around devices that generate high voltage is excess of 32.5Kv.
Oct 28, 2008 | Sony KP-57WS500 57" Rear Projection...
TV flashes blue, shuts off, and red power light flashes eight times?
either lamp is failing or cooling fans at rear blocked causing overheat
Aug 26, 2010 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500 57 in. Rear Projection tv When I press the power button there is no picture but the "timer / Standby" light flashes. Sometimes when pressing the power buttonthe light flashes and I hear...
CK your hori output Transitor and behind it is a blue high voltage capacitor 2k sometimes they will have small burt hole on them ,If it is OK then Replace your STK ICs example STK392-110 Mats has them 1-800-628-1118
Feb 15, 2010 | Sony KP-57WS500 57" Rear Projection...
Sony kp-57ws500 flashes blue, green, red then turns off
Re-insering the flyback wire is usually very easy. Push in and give a slght turn and check to see if grabbed. It sounds as if there is more issues than flyback wire. TV should turn on without one crt connected
Dec 14, 2009 | Sony KP-57WS500 57" Rear Projection...
TV flashes blue and then shuts off!!
this is most likely a short in the screen grid of the crt open the front lower under speaker cover and adjust the blue screen control .. turn it down with tv on might solve the problem
Mar 02, 2009 | Sony KP-57WS500 57" Rear Projection...
Screen flashes ble, then tv turns off
This is a common problem on that model, you have a bad blue tube, it is shorting out and the tv is shutting off to protect from furthur damage. Sony had a major problem with this it is not uncommon to have more than one tube bad. To have one tube replaced by a repairman will run you $500-$700 let me know if I can be more help?
Tim Nolan
Sep 12, 2008 | Sony KP-57WS500 57" Rear Projection...
Kp-57ws500
My tv too had a blue screen problem. Then it started to shut down after staying on for less than a minute. I thought that I would with a huge repair bill but I followed the directions at this link: http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html and now my tv works perfectly.
May 01, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500 57 inch TV
Probable convergence IC failure = replace both for reliability..T.
Nov 24, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
210 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
