Windows xp pack2,vpn
Since I've installed windows xp pack2, I can't use my VPN anymore...and that is terrible.I tried to disable windows firewall,but I couldn't. It says "windows firewall settings can not be displayed because the associated service is not running.Do you want to start windows firewall/internet connection sharing ICS service? and then it says windows can not start windows firewall/internet connection sharing ICS...
Please tell me what should I do?Thanks a lot
Best regards,
matty
    Genius:
  • 1,067 Answers
Try do windows up ? reinstall sp2 run cc cleaner free tool online dl new vpn software from microsoft
Posted on Jan 07, 2008
Cisco vpn disconnection through sonicwall firewall
This may sounds obvious but have you forwarded the correct ports through sonicwall for your VPN?
If you have, do you have any QoS running, it could be worth checking that VPN has priority over VoIP etc.
Do you get disconnects all the time or is it only during busy periods? You may be overloading your server, perhaps it's time for more RAM.
Oct 31, 2013 | SonicWALL PRO 2040 (01-ssc-5703) Firewall
VPN connection error
1) you are dialing the wrong number.
2) make sure you have good connection.
3) If using VPN, make sure the port 1723 and IP Protocol 47 (GRE) are opened.
Apr 04, 2008 | Televison & Video
I go to Tinychat.com and it says that my computer ip has been detected as a proxy/VPN. How do I change this? How do I fix it?
Go to Windows Firewall (Start -> Control Panel) and see if VPN has been enabled, if so try disabling it.
Oct 25, 2013 | Computers & Internet
I tried to install NetExtender client from SSL-VPN website to Windows XP (x64) with IE8 but getting "Failed to install NetExtender, the installation has been rolled back!" message. I already...
In Windows your security settings need to be set to accommodating this installation you can find the security settings for IE8 by going to tools then internet options set your security to low from your question it reads that you have done this already my research bring me to this option please read below.
Article Applies To:
SonicWALL SMB SSL-VPN Appliances and Software: SMB SSL-VPN 2000, SMB SSL-VPN 4000, NetExtender
Firmware/Software Version: 2.5 or higher
Problem Definition:
When installing NetExtender on any supported Windows operating system, the error "Failed to install NetExtender, the installation has been rolled back" may be observed, especially when the operating system is installed on a drive other than the default. This issue is resolved by upgrading the SSL VPN 2000 or 4000 appliance to firmware version 2.5 or higher and making another installation attempt.
Resolution or Workaround:
For each of the following possible causes of this behavior, an explanation, workaround, or solution is provided:
  • User does not have administrative privileges. With 2.5.x.x firmware and above, administrative privileges are required for initial installation only, previous versions require administrative privileges for each update.
  • Browser security settings. Add https://IP-or-DomainName to trusted sites, and set trusted sites security level to LOW.
  • Popup blocker. Disable all third party popup blockers.
  • Anti-virus or anti-spyware. Temporarily disable all third party anti-virus or anti-spyware solutions.
Source: SSL VPN 2000/4000 2.5 Release Notes this has been copied from doing my research this is not my material but a help post from another source. Thanks for using FixYa! do not forget to vote for me. John
Mar 12, 2011 | SonicWALL SSL-VPN NetExtender Adapter
Hi, when i try to install cisco vpn on my xp machine, it is throwing 1721 error.
Cisco VPN Client for Windows Vista, release 5.0.0.340, does not support the following:
blank.gifMicrosoft Windows NT, 98, and ME.
blank.gifSystem upgraded from Windows XP or earlier Windows operating systems to Vista. (Clean OS installation required.)
blank.gifCombination of Cisco Unified Video Advantage 2.1.2 and McAfee HIPS Patch 4 Build 688. To avoid system failures, uninstall either of these two applications, upgrade McAfee to the latest version, or use VPN Client 4.6.x.
blank.gifStart Before Logon.
blank.gifSmartCard authentication.
blank.gifIntegrated firewall
blank.gifInstallShield.
blank.gifAuto Update.
blank.gifTranslated Online Help. Online Help is provided only in English.
blank.gif64-bit Windows operating systems. For x-64 support, customers should explore with their Cisco sales representative the use of the next-generation Cisco AnyConnect VPN Client.
Nov 04, 2010 | Microsoft Windows XP Professional
Cisco VPN Client Error
Hello
Try to switch off the Cisco VPN Stateful firewall.
Apr 19, 2009 | Computers & Internet
I have a Surfboard SBG900 router and cannot connect to VPN
The issue you have is not due to enabling WPA. It is due to enabling Firewall protection. Either turnoff firewall or use custom option to enable required ports.
Nov 26, 2008 | Arris SURFboard SBG900 Wireless Router...
VPN Using XP Servers and D-Link WBR-2310
I had exactly the same problem. The solution is to set up pptp as a virtual server pointing to the lan ip of the server. Port forwarding only forwards the port but not the GRE protocol (pptp passthrough)
Jul 26, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
CANT GET VPN CONNECTION
the vpn connection from your home to work or the vpn connection from anywhere else to your home by vpn.
here you find a forum with the same problem:
http://broadband.motorola.com/consumers/support/faqs/surfboard_faq.asp#cant_login_vpn
Dec 07, 2007 | Arris SURFboard SBG900 (49402201900) Modem
Vpn error. 800
Resolutions: 1) if you have firewall, open TCP Port 1723, IP Protocol 47 (GRE). 2) make sure you can reach the VPN server by using ping. Sometimes, poor connection can cause this issue too. 3) You may need to updated firmware on a router or firewall if other OS (win9x/nt/me/w2k) works except XP. 4) The VPN server may not be able to get IP from DHCP for the VPN client. So, you may want to re-configure VPN host networking settings. For XP pro VPN host, go to the Properties of the VPN>Network, check Specify TCP/IP address and Allow calling computer to specify its own IP address, and uncheck Assign TCP/IP addresses automatically using DHCP. 5) Make sure no other secure software blocks your access, for example, if you use Norton secure software, you may need to add the remote client's IP so that the client can access. 6) If your VPN running on a Windows RRAS with NAT enabled, you may want to check the NAT settings. 7) If you can establish the VPN from the desktop at home but not from the laptop. Make sure no security software like Microsoft OneCare software that blocks the GRE.
Oct 01, 2007 | Acer Aspire 5100 Notebook
Computers & Internet Logo
114 people viewed this question
Alun Cox
David Payne
David Payne
