Question about Motorola Mobility MING A1200
Lost Contacts List
I lost all my contacts list. I can not input contact,on the screen reads
"fail to add phone contact".When I open message on icon,it shows "Waiting for DB..." It is doing that at all time.I tried to solve the problem by doing MASTER RESET but it did not work.
0 characters
1 Points
Lost contacts on my Palm Zire 31
No, only if you synchronized with another device beforehand. Using Palm Desktop, eg, you could synchronize and get the list back.
Dec 21, 2013 | Palm Zire 31 Handheld
I have lost my test message icon on my blackberry curve 9360 how do i get it back
My wife's 9360 just did the same thing, the message icon vanished. I took the battery out for ten seconds and that fixed it. Hope this helps. Jim
Dec 13, 2011 | RIM PDAs
Send Msg
start the message and the hit menu add recipients then hit name you want repeat for each name you want to add
May 21, 2010 | HTC Touch P3450 Smartphone
Cannot Add BBMessenger contact once it has been deleted!
Simply try adding contacts via PIN and not email. It works perfect!
Jan 17, 2009 | RIM BlackBerry Curve 8310 Smartphone
Copy list of contacts to simm card, delete Active Sync from phone
go into file explorer:
go to my device
copy the file called (pim)
paste it in the storage card folder -
if your phone is ever wiped, that file contains the entire phonebook - and its copied on your storage card.
Dec 08, 2008 | Motorola Mobility Q9m Smartphone
Sms messaging send to recent log
just text a few different people until the contact is no longer a "recent" conacts, i thinks its like the last so many contacts in the list, i'd check mine but my screens just broke
if your rich just get a new phone =]
Aug 23, 2008 | Samsung Ultra Smart F700
Blackberry 7100g
About fixed dialing
If you enable fixed dialing number (FDN) mode, your device only makes calls to contacts on your FDN list. Your device can dial emergency numbers in FDN mode, even if the numbers are not in the FDN list. If your service provider plan includes SMS, you can also send SMS messages to contacts on your FDN list
so if you have this enabled chances are you have to turn it off.
this is how you turn it on so you should be able to use it as a guide to turn it off.
Turn on fixed dialing
1. In the phone options, click FDN Phone List.
2. Click the trackwheel.
3. Click Enable FDN mode.
4. Type the PIN2 code provided by your service provider.
5. Click the trackwheel.
or if you wanna keep it on and add friends to the fdn
Add contacts to the FDN list
3. Click New.
6. Type a name and a phone number.
7. Click the trackwheel.
8. Click Save.
and finally some shortcut keys:
To open the phone, press the Send key.
To end a call, press the End key.
To call a selected contact or phone number, press the Send key. To call a speed dial number, hold the assigned key.
To add an extension to a phone number, press the X key. Type the extension number.
To call your voice mail access number, hold 1.
To type a letter in a number field, hold the Alt key.
To type the first letter on a key, press the letter key once.
To type the second letter on a key, press the letter key twice.
To turn on or turn off mute using the Mute button, press the Mute button.
To turn on or turn off mute using the keypad, press the exclamation point (!) key.
To turn speakerphone on and off during a call, press the period (.) key.
To change the volume during a call, roll the trackwheel.
Aug 02, 2008 | RIM BlackBerry 7100G Smartphone
Contacts disappeared from storage card when phone linked to new PC
When you make a new relationship - connection with a PC you should always backup the whole mailbox first.(messages,contacts,calendar...)Because the ActiveSync erases the "old" contacts.So,can u go back to the "old" PC (where the contacts are OK) and try to synchronize your contacts? Make a new connection with Act.Sync.If u want to update or add contacts,its better to do it via your mail client(MS Outlook for example) first and then synchronize your PDA.Good Luck.
Apr 30, 2008 | HTC TyTN Smartphone
Start-up Failed Contact retailer
try this tricks....
If you encounter situation like below on your 6670,
1. Blank screen phone unable to reboot.
2. Phone only able to boot-up to "Nokia" word screen.
3. Install some program but not able to uninstall it after that.
4. Error messages such as "Child Installer" keeps popping-up.
Do a Full phone formatting on your 6670! as steps below,
1. Make sure you have at least 3/4 charge of battery power left.
2. Backup your contacts list and personal files to MMC memory card.
3. Switch-off your 6670phone.
4. Press and hold 3 keys;
Green dial key, * (star key) & no. 3 key and then press the power on/off to swtich on the 6600 phone.
Remember, do not let go all of the keys and hold keys until you see a NOKIA turns to white screen LCD!
5. After a few minutes when the Full phone formatting completed, your 6670 will back to original system and factory settting.
All apps installed & not of the phones' default will be lost. If you did a backup on your mmc, you can restore it back to the C drive again.
but still you have the prob. Contact Re-tailer
go to the Cellphone Shop nearby and try to re-program your mobile or Hardware...
Thank you for rating this Tip.
Jan 20, 2008 | Nokia 6670 Handheld
Can not add new contacts on my W910i
dwnload sony erricsons update software and update it and see if it cumz back if not then return it back to your service provider.
Dec 22, 2007 | Palm Tungsten E Handheld
Motorola Mobility MING A1200 Logo
50 people viewed this question
Top Motorola Mobility PDAs Experts
David Payne
David Payne
Abby Carter
Are you a Motorola Mobility PDA Expert? Answer questions, earn points and help others
