Question about Hotpoint 23 in. BF41 Built-in Dishwasher
Dishwasher How to get rid of bubbles from dishwasher. Used fairy liqud to solve a blockage in pipes. Not sure if worked as over ran with bubbles had to switch machine off mid cycle. Any ideas??
  • 290 Answers
Let the suds die down then pour in about 1/4 cup of vegetable oil. Start the machine and let it run a few minutes then open the door and see if it is still sudsing. This will usually kill the suds. Some times I have to repeat again but not usually. Drain the water out and run through a short cycle with regular detergent and you should be good to go again.
Mike
Posted on Jan 07, 2008
  • Michael  Lindley
    Michael Lindley Jan 07, 2008
    Just wanted to follow up on you dishwasher and see if you got suds out.
    Thanks/Mike
Disosal leaking from bottom but also is backing water in Dishwasher when not being used.
A person familiar with plumbing needs to check your dishwasher and disposal and pipes that are connected with both of these.
To me it sounds like you have a blockage somewhere, could even be in the pipes, not the disposal or the dishwasher.
The leak of the disposal could be the disposal leaking or the plumbing pipes leaking.
God bless your efforts.
Nov 23, 2017 | Dishwashers
Miele dishwasher
you can go through this link http://www.miele.co.uk/Resources/OperatingInstructions/G%201142.pdf it contains the operational manual that will guide you on how to clear it.i hope that solves your problem
May 17, 2008 | Miele Dishwashers
Lights 2+4 flashing on dishwasher & won't drain
Doe the pump make a sound as if it's trying to pump out? As it sounds as though your pump is either obstructed, or the outlet waste water pipe from back outside of the dishwasher to the drain, maybe bent somewhere or blocked & not allowing water to exit the dishwasher, if both are clear of blockages & no noise of the pump kicking in to empty the dishwasher then I would definitely say the pump has failed...
I hope this helps....
Feb 22, 2018 | Dishwashers
Water did not drain from the bottom
Hello Cheryl, There are a couple of possibilities. When the dishwasher drains the dirty water it is a time based function. This leads me to believe it is a blockage or partial blockage in the drain hose.
Here is an example. (If your dishwasher drains into your garbage disposal) washing dishes you put scraps into the disposal and forget to turn it on after you are done. The disposal is filled with scraps this restricts the flow of dirty waterfrom the dishwasher. If the flow is restricted less water is being drained per second from the dishwasher. This is why the dishes still looked clean and there was still water in the bottom of the dishwasher.
(if your dishwasher drains into a drain pipe) there is blockage or partial blockagein the dishwasher drain hose. if the sink drains slowly the blockage is in the main line
Hope this helps
Joe Connolly
Nov 02, 2011 | Frigidaire Dishwashers
Belling dishwasher idw603 need help on error E5
According to people who have had this problem before (error code E5 means blockage in the drain circuit) have solved it by
1:Remove the metal front panel from the dishwasher. this may be hidden by you kitchen kickboard its held on with 5 posi screws.
2: find a round black plasitc lump, similair to a yoyo!.
3:remove the rubber pipe that goes into it and blow down the pipe(you will hear air blowing into the dishwasher) then blow into the plasitc lump(you should hear it rattle)
4:put it all back together.
The black plastic lump is the pressure sensor, water gets stuck in it so the dishwasher thinks theres water inside so tries to pump it out but the pressure sensor still says there is water in so you get the error. Blowing through clears the water.
It is also a good idea to use dishwasher cleaner kit now and then- this is available from the super market in the dishwasher detergent section and is used with an empty dishwasher. Will get rid of all the muck that collects in the hoses and the drain.
Hope this helps.
Feb 17, 2010 | Belling Dishwashers
Squealing noise
The pump motor is beginning to seize up. You may be able to take the dishwasher apart and lubricate the bearings and keep it going for a while, but at some point you will likely have to replace the pump motor assembly.
Jul 01, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Sounds like dishwasher is running but no water coming out (there are no broken pipes or leaks)
I had the same problem. The motor is working (humming) and my dishwasher goes through the whole cycle without water. I googled it and found it on a website. Sorry I don't remember which website. Basically, it said to put some hot water in the bottom of your dishwasher and add some citric acid. I added 2 small packets (2 oz each) and filled the bottom of the dishwasher with hot water until it covered the motor or the drain of the dishwasher and left it overnight. The next day my dishwasher started and ran perfectly fine. That was over 4 months ago and I have not had any problems.
Mar 24, 2008 | Dishwashers
Bosch dishwasher problem
remove the kick plate below the door. youll see a white tray behind the kick plate. theres water in the tray thats activating a overflow switch. with a towel or 2 remove as much water from tray as possible. this will solve problem
Nov 16, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Neff Dishwasher won't drain
I've had this problem a couple of times with my dishwasher. In both cases, the cause was a shard of broken glass that had managed to get past the filters and jam itself underneath the impellor. Hard to see, but easy to fix. First ladle out the water.
Pull off the lower rotor arm, unscrew the filter and take out the filter bowl, tray and cylindrical filter. Get as much water as you can out of the filter cavity.
Then, using a Torx-20 driver, remove the screw holding the impellor cover and lift the cover off. (this is the small bit of plastic at the left end of the filter cavity.) Check whether the impellor can rotate freely by spinning it with your finger several times - if it jams or grinds, then there's probably something jammed under it. (It may seem to be fine at first, so do check thoroughly, as any debris can move around with the water flow and only jam occasionally) You may have to use a cocktail stick or similar to poke out anything that's stuck underneath.
Glass is a particular problem, since it's almost impossible to see when there's any water around (it's easy to cut yourself too!)
Anyway, that's worked twice for me now - and I didn't have to even move the machine out of its cupboard to fix it.
Hope that helps.
Nov 10, 2007 | Dishwashers
Dishwasher is stuck on the rinse cycle
make sure the float or metal probes in the unit are clean.they sense water and if anything is on them it will cause a malfunction in the unit.
Aug 27, 2007 | Hotpoint 23 in. BF41 Built-in Dishwasher
Dishwashers Logo
174 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
