That is a tough one. Can you make something and bend it into shape? Get some good double side stick tape with a dab of H/S cream under a little piece of metal to draw away some heat. I'm sure you'll come up with a better idea.
Comments:
Nov 12, 2009
- I don't think that hold down wire has any connection other than a possible ground. Isn't it just there to hold the chip in place and maybe dissipate some heat? Send me make and model and chip U number and I'll look it up.
issue with acer aspire X3812, the dvd writter can read CD, burn cd but it does not work when i want...
(More)
issue with acer aspire X3812, the dvd writter can read CD, burn cd but it does not work when i want to burn DVD. No problem to read DVD : video or data. It starts burning then after 5mn stop, eject the DVD and explain that there is an issue so put a new blank DVD. Another point : I cannot create the rescue DVD, it fails (link to the DVD burn issue)
Umax 2200 usb scanner & Vistascan 3.55u in Windows XP Scanner installs to the default XP...
(More)
Umax 2200 usb scanner & Vistascan 3.55u in Windows XP Scanner installs to the default XP scanning software, but I have not been able to install the scanner so that it works with the Vistascan software. I much prefer Vistascan as it is much more user friendly & offers more flexibility. Any help would be appreciated.
how do i make adjustments to the dclcd s1702d monitor. the screen is completely light green. i get...
(More)
HOW DO I MAKE ADJUSTMENTS TO THE DCLCD S1702D MONITOR. THE SCREEN IS COMPLETELY LIGHT GREEN. I GET NO RESPONSE TO ANY OF THE BUTTONS LOCATED AT THE BOTTOM FRONT OF THE MONITOR. THANK YOU
