If you hear like whirling sound and vibration on the TV,it looks like the color wheel bearing is loosing balance and is hitting the housing unit,the color wheel spins @ 5000 rpm you will definitely notice when is going off i have this link that i found i hope it helps http://guides.fixyourdlp.com/samsung/bp96-01579a.php?click=52978 it's not your TV model but at least you will have and idea of what you need to look for.
good luck
Was this helpful?
Yes
No
Popular Solutions for Samsung HLR5067WX 50 in. Rear
i just bought a used HCN4226wx/xaa, the blue convergance lines are off each other in the convergence...
(More)
i just bought a used HCN4226wx/xaa, the blue convergance lines are off each other in the convergence adjust menu and they wont adjust, and also there is an image burned in the back ground of the screen, can you replace the screen? whats the p/n? please help
This set has green plaid screen on all analog channels. HD channels look pretty good. Changed the...
(More)
This set has green plaid screen on all analog channels. HD channels look pretty good. Changed the analog board, part # BP94-02049E. No change. Which board is it?
i have a 2005 samsung hpl5067w 50" projector tv. when i hook up any input devive i get a flashy...
(More)
i have a 2005 samsung hpl5067w 50" projector tv. when i hook up any input devive i get a flashy garbled colored picture. when i go into the menu of the tv it displays the menu fine.
