Pioneer KEH-1700. Hi, while trying to remove the unit from the slide-in sleeve in the dashboard and...
(More)
Pioneer KEH-1700. Hi, while trying to remove the unit from the slide-in sleeve in the dashboard and not having the installation manual to hand, I managed to insert one of the extraction pins incorrectly. As a result, when I had removed the unit, there was something rattling inside. This turned out to be the "double arrow-hook" plastic part into which the faceplate clips. Can someone please tell me how to reattach this part? It has two "arrowhead hooks" on one edge, and a tiny little hooked projection on the other. Perhaps this is a connector for a holding spring or another part which are now missing. Please would someone explain how to fit and fix my radio/cassette, preferably with a diagram and the part numbers for any missing/broken bits and where to buy them? Many thanks, jenni (from Edmonton, Alberta, Canada)
none of my interior lights work including the a/c lights could this be afuse problem and where would...
(More)
none of my interior lights work including the a/c lights could this be afuse problem and where would this panel be located
I just had to replace the radio in my work truck - i got a used pioneer keh 1700 (casset type) at...
(More)
I just had to replace the radio in my work truck - i got a used pioneer keh 1700 (casset type) at the auto wrecker all works but can't figure out how to set clock! Any help here?
