Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
Time left display flashes LE.
By one_moore on Nov 10, 2009
Best Solution
posted on Nov 10, 2009
Very Helpful)
jan mczeal
Rank: Guru
Rating: 87%, 245 votes
It is a locked motor error. One of the following is causing the problem but you may need the help of a qualified appliance technician:
  1. The connector (3-pin, male, white) in the motor harness is not connected to the connector (3-pin, female, white) of the stator assembly. Connect them properly.
  2. The electrical contacts between the connectors (3-pin, male, white) in the motor harness and 4-pin, female, white connector in the main board assembly is bad or unstable. Clean the connectors and connect them properly.
  3. The motor harness between the stator assembly and main board assembly is cut or open. Reconnect or rewire.
  4. Motor winding is defective. Check the resistance between the terminals of the stator. Resistance should be between 5 to 10 ohms, else replace the stator.
  5. The hall sensor is out of order/defective. It is located at the stator assembly. If the hall sensor is out of order, it cannot detect magnetic field and the main board sees it as the rotor is locked then displaying the error code. Replace it if no evidence of defect is found above.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
elite oasis is that a quaitly machine
Answer
What is the most reliable top loader washer to buy?
Answer
I'm trying to find a replacement bearing ring for the drum of a Bosch 320V washing machine. The ring... (More)
Answer
the water has not drained away and it did not spin.Now, no cycle works . has the pump broken?
Answer
I have a Siemens washing machine model WXLM1260GB that will not move on automatically to the rinse... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Washing Machines:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14885
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
