Question about Whirlpool Duet GHW9150P Front Load Washer
DETERGENT LEAKING DOWN FRONT OF MACHINE
When I add detergent and shut the detergent door, it sometimes starts lekaing down the front of the machine through the dteregent door. I am not using too much detergent (actually I don't feel like I use enough). Why is this happening?
Thanks!
  • TomJo Feb 03, 2008
    We have the same problem on a new Whirlpool Duet Sport washing machine purchased in Sept 2007.
    Problem has been there since delivery of the machine.
    Master:
  • 619 Answers
THE HOSE LEAKING /IF LEAK DUE TO LOSE OF THE HOSE IF ENOUGHT CUT SMALL PORTION THAT HAD BEEN EXPANDED AND RETURN PUT CLAMP ON IT.
Posted on Jan 07, 2008
Hi, just wondering if someone can help our washing machine seems to develop a puddle of water around the front and after a wash there are drips running down the front panel. Just wondering what would be...
You could have a bad seal somewhere. Then again, you could be using the wrong type or amount of detergent. Newer models use new detergent formulated with low suds. They also need less detergent per load. Brand and model would be good information to add.front load washer 25362436-awph1b3yhxdrnyqdcrsrelkr-3-0.jpg
Jan 09, 2015 | Washing Machines
My front loader washing machine is leaking.
the tube that runs to the drum from the detergent tray may be clogged. use something to slip into the tube to see if it is clear or not.
Jun 27, 2013 | Whirlpool 8572546 Duet Sport Stacking Kit
I have a Miele W4840 front load washer and there is water leaking from the door. I've checked the seal and it doesn't seem to be damaged, but there is a definite leak. Please advise.
first make sure your detergent drawer is not popping open. water will run out from beneath the drawer, run over to the top of the door, run down the door, and then straight down to the floor. If you are not leaking out of the detergent drawer, the next thing down is the bottom of the glass door. look at the glass where it contacts the door seal at the bottom. It should be clean and smooth. Most likely you will find lint, hair, and soap residue. that needs to be cleaned off. any surface imperfections will cause a slow drip or trickle of water to come out of the lowest part of the door. If that is fine, and it is still leaking, open the cover to the drain pump on the bottom right of the front of the machine. Make sure that drain pump filter is tight. run the machine with that little drain access door open and see if you are leaking from there. If none of the above helps, and you are still getting water leaking from the door, miele has designed a new clamping ring for the door seal. Call them and make arrangements to have it replaced.
May 09, 2011 | Miele W 4800 Front Load Washer
My washing machine is leaking from under the detergent drawer and down the front of the machine. Any ideas?
Make sure that the drawer is clean, sometimes soap powder (detergent) can clog up into a lump and as water is sprayed into the drawer its can spray up around the top and down under the drawer.
Take the drawer out all together to get a good look inside it and into the drawers catchment area.
Mar 29, 2011 | Washing Machines
How to operate the washing machines front load washer brandt bf850
  • Open the front door and load the clothing into the washing machine. Check the owner's manual for the maximum load size. Overloading the washing machine may interfere with its ability to spin the clothes and rinse them clean.
  • Fill the detergent receptacle on the front of the washing machine, making sure not to fill it past the indicated line. Always use a liquid detergent that is designed for front-loading washing machines.
  • Add bleach or fabric softener, if needed. Most front-loading washing machines have a section for fabric softener inside the detergent receptacle. Check the instructions on the bleach to find out when it should be added to the washing machine.
  • Close the front door of the washing machine and make sure it locks into place. The machine usually will not turn on unless the door is securely locked.
  • Check the owner's manual to find out how to select the different options and wash cycles. As a general rule, use warm or cold water for most types of colored clothing. Hot water should only be used when washing white cotton items.
  • Start the front-loading washing machine and let it run through the entire wash, rinse and spin cycles before opening the door to unload the clothing.
  • Please rate this solution. Regards.
    Nov 04, 2010 | Brandt WFH1176 Front Load Washer
    Kenmore Elite HE3 water is leaking out the front door
    These are notorious for the door boot leaking. Look for any tears, rips, pinholes in the door boot. Also make sure the door is parallel with the machine. Most likely it's the boot. Parts about 100.00. Labor can run from 110-140 depending where you go.
    Mar 16, 2009 | Kenmore Elite 45986 Front Load Washer
    Machine is leaking detergent
    check inner gasket for small hole
    u can take front off by removing screws from around inside door frame (including hinge screws) the panel will pull out towards u then u might be able to c where its leaking better
    Jun 01, 2008 | Maytag Neptune MAH7500WH Front Load Washer
    (front load ATF6000ES) is constantly leaking detergent
    the loose vane cant affect leaking first open the drawer look on the back Left side of the drawer push down on the tab and remove the drawer take it apart and clean it well top and bottom clean the inside of the drawer hsg and look for cracks on the top panel remove the two screws at the back and remove the panel reassemble the drawer assembly put detergent in it start the washer take a flashlight and look for leaks
    Mar 13, 2008 | Frigidaire Affinity ATF7000E Front Load...
    Water leaking
    There is a small plastic "gate" that is left down for liquid detergent and moved back and up for powder detergent. If this piece is left down and powder detergent is used, the water leaks and the detergent won't go into the washer properly.
    Oct 13, 2007 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    203 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
