Question about RCA P52939 52" Rear Projection Television
RCA big screen has gone crazy!
Rca 65" has a mind of it's own, volume does not work. changes channels on it's own. menu screen comes up on its own. How do I fix the problem?
    Novelist:
    Champion:
  • 211 Answers
Sounds to me like you may have a cold solder joint in a board ( loose lead on the pc board ) or you might have a b ad eeprom causing the problem. You may need to replace the main board. Also another sitution I have come across is a stuck button on the tuning strip board ( the board/switches that change channels, volume etc ) on the tv. maybe also since the remote sensor is light senative, it may be in the line of the sun ( cover the ir senor on the front of the tv to illaminate that problem ). Good Luck and if you the suggestions don't correct the problem. email me at wyoed1@aol.com or continue with this at this address. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
RCA TV picture bigger than screen
if the tv width is ok try entering to service menu (do not use remote control) as follow:
1) turn the set on.
2) press the menu button and hold it down while pressing the power button.
3) while holding down the menu button release the power button and press
the volume + button.
4) The screen will display a one line menu, on the left the parameter P00,
and on the right the value of the parameter V00
5) release buttons.
6) using the volume + button change the right parameter until 76
7) using the channel down button change the left parameter until 06 (vertical size)
8) whith the volume + or volume - adjust the screen size.
9) when your tv is OK back to parameter 00 using the channel up button.
10) press menu button.
and trouble solved.
Mar 05, 2010 | RCA F32650 32" TV
RCA D52W23 tv
Front Panel Board needs cleaning or replacing Call Encompass Parts 1-800-638-3328 and for just contact switches Call Mats 1-800-628-1118
Jan 18, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an RCA 27in. screen TV. Cannot program, all is fuzzy.
try unplugging and plugging back in 2 minutes later. go to menu and find channel selection. scroll down to where it says channel. then using volume up and down buttons. will add or erase channel. just play with it and you will see what im talking about. go to channel 4 and press volume up. this will save channel 4 in memory. if no work, try turn on video souce and do a auto program in menu. fixed. enjoy!
Nov 09, 2009 | RCA F27252GY 27" TV
MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Feb 17, 2009 | RCA P52926 52" Rear Projection Television
Volume & Menu screen flipping out
Replace all of your contact switches on front panel board power/off/on vol- vol+ ch- ch+.
Jan 05, 2009 | RCA HD52W66 Projection Television
Lost orig remote/ fpa lock on
I have a 20f511t RCA Tru Flat with FPA lock on, using an universal GE remote press setup, then menu, channel down to preferences, press enter, channel down to FPA LOCK, volume up to change to on or off, press menu to remove, all shoud work now
Nov 23, 2008 | RCA 20F420T 20" TV
RCA d52w20?
ok ...first question ... what happens when u push menu?...do you get any osd...on screen display...menues volume.. channel number. HOw bout any sounds... the light comes on and the stays on..?
Dec 03, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Cannot operate tv manually or with remote
may have a corrupted eeprom which means you`ll have to call a tech, one thing you can try is;
Un-plug the tv`s AC power cord, wait 30 seconds, plug back in and pray, this will set re-set the micro to the default mode which may have gotten glitched by a power surge, hope it works for you.
Nov 30, 2007 | RCA P52926 52" Rear Projection Television
FPA Lock
After doing a little research, it looke like the front panel lock , can only be removed from the parental control menu using your remote. If your universal remote does not get you into the menu, see if you can borrow a friends rca remote long enough to get you into your menu & remove the fpa.
Nov 03, 2006 | RCA 14F512T 14" TV
RCA P52939 52" Rear Projection Television Logo
101 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
