Look for a tiny slide switch on the edge of your usb kingstone drive and slide it. If it is up then slide it down or if it down position then slide it up. :-)
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Kingston 2 GB USB Hard Drive
How to remove the write protection in drive on Volume/Devices/Hard disk/DC6 I need some help.. I...
(More)
How to remove the write protection in drive on Volume/Devices/Hard disk/DC6 I need some help.. I cannot write or move files on My Kingstone 4GB Data traveler. The message notification says it is write protected and ask to remove the write protection. Unfortunately, I don't know where to find the write protection or where to start to remove the write protection.
Same Problem!!! the Error is |X| Cannot Copy the file: Cannot Fine the Specified file Make Sure you...
(More)
Same Problem!!! the Error is |X| Cannot Copy the file: Cannot Fine the Specified file Make Sure you specify the correct path and the filename my USB devise having problem SKYMEDI USB drive 2GB and it cant be reformat the device is empty plz tell me if this device will not be used forever or you can do this problem.. plz help me on this error Thanks!!
I just got a generic 16gb flash drive and just about every media file i copy there gets corrupted....
(More)
I just got a generic 16gb flash drive and just about every media file i copy there gets corrupted. Altough it's not every time it's about 95%. Is there anything i can do to remedy this or does the problem lie with the drive itself? Thanks.
