Question about KWorld PCTV CONVERTER KW-PCTV-1600 RT (KWPCTV1600)
Laptop Can I connect the converter to a laptop
  • 1 more comment
  • Anonymous Dec 20, 2008
    I cannot go from internal screen to external vga screen. the f 7 button doen's make anything happen. how do i go to display properties and display the external view?
    I am trying to hook up my sony laptop to my tv via a kw-pctv box. the problem is I cannot switch my laptop from the regular screen to the vga external output. the f 7 key does not work. how can i go to properties and switch to the external output?
  • Anonymous Apr 03, 2009
    Get color bars , tried lowering the resolution bit no luck
    Novelist:
    Scholar:
  • 136 Answers
Yes you can.
You will need the VGA cable to plug from your laptop to the converter then the converter to the tv that you want to send the signal to.
However, most laptops will have an svideo output for tv so you may not even need this converter unless you want to switch between pal and ntsc.
One thing to note is to switch your laptop to external output there should be a function button on your laptop and one of the F function with a logo of a small computer on it to switch between laptop screen or external vga. Alternatively you can go to display properties and select the external view. On a IBM laptop its F7.
good luck
smeags.
Posted on Jan 07, 2008
    Genius:
  • 1,067 Answers
Did u try yet does yoru labtop usb 2.0 ready what model of pc and dl latest drivers for it ?
6ya staff
SOURCE:
Toshiba large screen - connected to my laptop with an Auvio USB to HDMI adapter.
First confirm that you do not have a VGA connection for a PC in the back of your TV. Many PC's connect directly into the TV's with VGA connection provided. If only HDMI then a converter can be a reliable alternative.
A VGA to HDMI converter may be a better solution. This particular device identified in the link has the power from the USB of the laptop to operate, the sound from the audio out of the laptop, and assuming you have a VGA out for a monitor the connection to the converter will give you choice of resolution.
There are many different units available and the one in the ink is just an example.
Hope this helps?
Syba Portable VGA to HDMI Converter with Audio Support
Oct 31, 2016 | Toshiba Computers & Internet
Want Connect to My Laptop HDMI Output
If your TV has no HDMI input to connect with your laptop's HDMI output, surely you need a converter. If the laptop have A/V output, and the TV too have an A/V input, you can connect in between, using an AV cord. google.com/+GopakumarGopalan
Nov 25, 2013 | Daewoo DTQ-27U1SC TV
Element tv wont see laptop
Connecting laptop VGA port to HDMI port on a TV
VGA to HDMI converter is required to connect a laptop to a TV with HDMI input. The VGA signal does not have an audio component. You need to connect an audio cable from the audio/headphone port on your laptop to the audio connector on your TV. There are HDMI converters with Audio input so you do not need to connect an audio cable to the TV. The audio is connected to the HDMI converter and then passes the audio with the video data to the HDMI cable to HDMI port on the TV. Check out these WEB site for these HDMI converters. http://www.aten.com/products/productItem.php?model_no=vc180 http://www.sybausa.com/productInfo.php?iid=1174 http://www.topbuy.com.au/tbcart/pc/Audio-VGA-to-HDMI-Video-Converter-Box-HD-HDTV1080P-p164633.htm
Mar 14, 2013 | HP Pavilion Computers & Internet
Can not connect hdml wire to my philips led tv with my dell laptop. what to do
If your laptop does not have a HDMI port then you need a VGA to HDMI converter. Connect this converter to your laptop and then connect it to the TV using a HDMI cable. You also need to connect the audio out port on the laptop to the audio in on the TV. You can get a combined audio input with some HDMI converters.
Check out this WEB site.
http://www.proaudiovisual.com.au/vga-to-hdmi-converter-adapter-and-upscaler-video-audio-full-hd-1080p/
Mar 05, 2013 | Computers & Internet
Connect to tv but no hdmi socket on laptop
LOL, you're up the creek without a paddle unless you buy some type of Converter that goes between the laptop and the tv. They both have to have the same type of connection or you will need a converter to make it look like they have the same.
Does your Laptop have a VGA Connection, does the tv have a VGA connection, if so use it. Otherwise you're going to need some type of converter that will convert the vga signal/connection out of your laptop to a HDMI connection that the tv has.
Apr 07, 2012 | Toshiba Satellite M30X Notebook
Is it used to connect internet
No this is not used to connect internet.This converter is used to connect your laptop to TV using USB port.Because some laptops doesn't have VGA ports.
Thank you
Nov 21, 2010 | Vga To Hi-Speed USB 2.0 Converter
My formac dvi monitor wont work as a 2nd monitor for my laptop
Try a monitor that has a vga output only, sometimes these laptops can't recognize the difference when there is a converter involved. It doesn't see the signal properly.
Try that and if a regular monitor works with vga then you know that monitor may not be compatible with that laptop because of the converter. You could also try another converter as well to see if that fixes the problem.
May 07, 2010 | Formac Gallery 2010 20.1" LCD Monitor
Attach HP PS2 Keyboard to Dell Laptop
hmm, Interesting
Because the Laptops mostly do not have the PS2 Port,
if you are using the converters connecting the USB to the PS2.
then It may be the junction related issue.
so find a USB mouse and connect it directly or try with another Converter.
that should work.
Jul 15, 2008 | Computers & Internet
PC to TV connect
Yes, there are converters that can take the VGA terminal on your laptop and convert them to RCA or S-Video. As for the black and whit, try using a different cable, otherwise the jack is bad, and you would have to open the case to fix it.
Jan 02, 2008 | Computers & Internet
Open Questions:
Televison & Video Logo
268 people viewed this question
Top KWorld Televison & Video Experts
Ekse
Marvin
Marvin
Miroslav Totovic
Level 1 Expert
Are you a KWorld Televison and Video Expert? Answer questions, earn points and help others
