Question about Magellan eXplorist 400 GPS Receiver
Doesn't opperate when i turn power on, message says "Press ENTER to configure NAND Press ESC to cancel". If I press either Enter or Esc, the unit just goes blank and nothing at all happens. I had never seen this screen till the GPS quit working.
  • 1 more comment
  • Jimchez Jan 10, 2008
    I have the same problem. Magellan says the memory has been wiped out by lack of use.
    The remedy is send it to them, they will repair it if it is out of warranty for $105.00.
  • Anonymous Sep 04, 2008
    my explorist 400 cant go to my maps
  • Anonymous Sep 30, 2008
    Mine is doing the same thing, How do they fix this?
Posted on Mar 06, 2008
Shows ERR when turned on
Hi, If you can't get it to work, try to do a factory reset.
Turn the unit off, then Hold the PRINT and ESC key down and then Press the power button. KEEP HOLDING THE Print and Esc key down for 2 seconds and then release both of them. You should see a message in the display INT?, Press SET to Reset your printer, or Esc to cancel.
Hope this helps.
Mac =)
Dec 28, 2013 | Casio KL-60 label maker
Shows ERR when it is turned on
Hello, If you can't get it to work, try to do a factory reset.
Hope this helps.
Best wishes
Mac =)
Error code 0xc18a0201
Hi.
The code means Ink System Failure. First disconnect power cord to reset the printer and test using different cartridges.
If that does not work try the procedure below:
"Press and hold the "left arrow" key.
Press the "Setup" key and release both keys.
Display should say "Enter Special Key Combo"
Press and release the "OK" button
1. Press and release the right arrow button until the display says "System Configuration Menu".
2. Press and release the "OK" button.
3. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
4. Press and release the "OK" button.
5. Display should say "Hardware failure status: Clear. Press OK to clear".
6. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
7. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
10. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use.
NOTE: If the error is still there, or reoccurs replace the unit."
Procedure from http://www.fixyourownprinter.com
Apr 23, 2011 | HP Photosmart C5180 All-In-One InkJet...
Oxc18a001
1. Get the unit into the ?Support Menu? by following the steps below. A. - Press and hold the ?*? key. B. - Press the ?#? key and release both keys. Display should say ?Enter Special Key Combo? C. - Press and release in sequence the ?1?, ?2? and ?3? buttons. 1. Press and release the right arrow button until the display says ?System Configuration Menu?. (on C8100 use Touch Screen) 2. Press and release the ?OK? button. 3. Display should say ?Hardware failure status?. If not there already, Arrow Key over to ?Hardware failure status?, 4. Press and release the ?OK? button. 5. Display should say ?Hardware failure status: Clear. Press OK to clear?. 6. Press and release the ?OK? Button. Message changes to ?Hardware failure status Cleared. Press Cancel to continue?. 7. Press and release the ?CANCEL? button as many times as necessary, so that, either the ?Welcome to Photosmart Express? screen appears, or, the ?Ink System Failure? screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. 8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. 9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer 10. Turn the unit on. The printer may display message ?USE POWER BUTTON TO SHUTDOWN THE PRINTER? followed by ?PRESS OK TO CONTINUE?. Press OK.
May 27, 2010 | HP Photosmart C6180 All-In-One InkJet...
0XC18A0101
May 25, 2010 | HP Photosmart C6180 All-In-One InkJet...
My eXplorist XL is locked up
Error message at start-up reads: "Press ENTER to continue NAND, Press ESC to cancel". Either choice I seclect and the unit shuts-down.
"With you XL turned off press nav + power; then change the numbers in the box from 00 to 95 by using the joystick and then press the joystick itself; (ENTER), accepting what is proposed...
Either FORMAT or SCAN... LET IT RUN!
After turning the gps on again and pressing enter the NAND will be configured and your gps will become in order again. Your system will immediately start to re-set itself.
If necessary, in usb file transfer mode, reload the basemap in the directory background maps..."
The only difference is that I had to load my SD card in the unit for it to work during the FORMAT.
My unit is NOW re-booting back to normal!
Sep 02, 2008 | Magellan eXplorist XL GPS Receiver
Error Message? "Press ENTER to configue NAND Press ESC to cancel"
With you 500 turned off press nav + power; then change the numbers 00 in 95 by using the joystick and and then press the joystick itself; accept what proposed.
after turning the gps on again and pressing enter the NAND will be configured and your gps will become in order again. if necessary, in usb file transfer mode, reload the basemap in the directory background maps
May 24, 2008 | Magellan eXplorist 500 GPS Receiver
Configure NAND on Start up
I finally wound up deleating the base map useing the Maintenance codes, which has now left me with another problem and that How do you rload the basemaps from Mapsend Lite?
Stewart
Mar 16, 2008 | Magellan eXplorist 500 GPS Receiver
Explorist 500
Dec 28, 2007 | Magellan eXplorist 500 GPS Receiver
Explorist 500
i had the same problem you have to contact magellan and they will tell you it needs to be sent in for repairs and they will send you an email or give you a phone # for the closest repair center to you
check this link for the magellan technical support closest to you https://www.magellangps.com/about/contacts.asp
Oct 19, 2007 | Magellan eXplorist 500 GPS Receiver
Magellan eXplorist 400 GPS Receiver Logo
194 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
