Olympus EVOLT E-410 Digital Camera
Problem for Olympus EVOLT E-410 Digital Camera
The camera works fine on auto settings, but when I
By scheller on Nov 10, 2009
The camera works fine on auto settings, but when I try to use it in P, M, S, or A, the image is very dark.
Comments:
Nov 10, 2009
- It happens with both lenses. When there is no lens attached, I can't judge the quality without a lens attached. I do hear the secondary clicking noise a few seconds after I take a picture. I can override the exposure with the exposure button.
Clarification Request
Posted by Obertelli on Nov 10, 2009
Does this happen with all lenses or just one? What happens when there is no lens attached?
Best Solution
posted on Nov 10, 2009
Very Helpful)
Obertelli
Rank: Guru  Cameras & Camcorders  Expert
Rating: 94%, 300 votes
When I've encountered this problem before it has been caused by a faulty aperture mechanism in the lens, but your answers to my questions pretty much remove that as a cause.
All that leaves as the culprit is the camera body. If there was a genuine fault then the same fault should be occurring when in fully automatic exposure mode, and the fact that you can compensate for the fault using the exposure compensation button is good news as it probably means that the fault is due to an inadvertent camera setting: the exposure compensation function is inoperative in fully automatic mode. The E-410 has two user-definable "custom reset" settings (page 70 of the manual) and I suspect these may be the cause.
I suggest that you go into Menu and then to the camera 1 symbol. From here you'll see "Custom Reset Setting" with the options "Reset", "Reset1" and "Reset2". "Reset" restores the camera to the default factory values and should cure your problem. Note that afterwards, the file numbering on the photos you take will also be reset so you may wish to manually adjust the file numbering afterwards to continue where you left off with you last photo. Not doing this will result in file name conflicts when uploading images to your computer.
If this doesn't fix your problem then the E-410 definitely has a fault and it will need to be resolved by an Olympus Digital service centre as the cause will be beyond any DIY resolution. The fault will likely be a software rather than a parts issue so a repair is likely to be cost-effective. Your camera had a one year worldwide manufacturer's warranty when sold new so it's possible that the camera is still covered (the E-420 was released early last year, but new E-410s were still being sold by some retailers early in 2009). There was also an option to extend the warranty so if the standard warranty has expired you might still have cover.
Normally I'd test all of this on my own E-410 or E-510 (same menus/software) but my wife has gone to France with them!
Hopefully I've hit the mark and been of some assistance. If so I'd be grateful if you'd return the favour by rating my answer.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Dead on the money! Thanks for your help. " - scheller
Popular Solutions for Olympus EVOLT E-410 Digital
Questions and Unsolved Problems for Olympus EVOLT E-410 Digital
Do you recommend Olympus EVOLT E-410 Digital Camera?
Answer
Answer
when i take a snap after taking the snap it shows no memory . when the memory is insected .
Answer
I must of touched something because when I clic it it delays
Answer
My E500 stopped uploading photos. When I plug it in with the usb all I get is a blank screen. It's... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Olympus EVOLT E-410 Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
