door lock stuck on bosch axxis washer. when i press start, door lock light comes on and clicks...
(More)
door lock stuck on bosch axxis washer. when i press start, door lock light comes on and clicks repeatedly...will not let me open, will not let me reset by holding start button down. any suggestions?
My display is out on our washer and I need to know what needs to be replaced and how much it will...
(More)
My display is out on our washer and I need to know what needs to be replaced and how much it will cost... I have a Bosch Axxis+ WBM22 front load washer. Purchased in 2004.
pump block message. drained with wet-vac, pump impeller is spinning. worked through soak/drain...
(More)
pump block message. drained with wet-vac, pump impeller is spinning. worked through soak/drain cycle. in wash cycle it worked until rinse cycle (when it fills with more water) then it stopped and message displayed. checked hoses, pump motor sounds like it is running with no water flow before message is displayed.
Have a Bosch WFF 1401 and when gets to last spin on the fast wash cycle, it drains but does not...
(More)
Have a Bosch WFF 1401 and when gets to last spin on the fast wash cycle, it drains but does not spin, thereby when door opened, water remains and clothes are soggy and also sometimes soapy.
