Question about Symphonic WF803 DVD Player/VCR
Hooked up don't work
I'm not sure I have right it's connected to a / through a dish box then to samsung TV
Hook the DVD Combo unit to the Video input of the TV. Not through your Dish Box. Then to View the DVD/VCR, switch the TV to the Video Input. Good Luck and have a great weekend
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
6ya staff
SOURCE:
Hooking up older Samsung TV to Roku and Dish devices.
If there are not the proper connection points then you are stuck you need to buy a new TV
Sep 04, 2016 | Roku Televison & Video
I have sound from satelite box through bose 321 but no picture on tv
First, you need to run the coax cable from your satellite dish to the "cable in" input on the back of your satellite receiver, not the Bose. If your satellite receiver has an HDMI OUT, and if the Bose has an HDMI IN,run hdmi OUT from the rec. to the Bose IN, then keep your HDMI connection from the Bose OUT to the TV IN as is. Make sure you've selected the correct input on the TV menu. As it is right now, you're not delivering any video signal at all to the TV!! -only audio(red and white). There are a couple other ways, but they won't give you the same quality. I assume this is HD, right? If you CAN do it this way (i.e. if you have enough HDMI ins and outs), it's the best possible hookup and you won't need the composite (red, white and yellow) at all. By the way, it's the yellow connector that carries the video signal; the red and white are audio left and right. If you can't hook it up all HDMI, disconnect the "separate cable" (I'm not sure what that is or what kind of cable or what it's for)and plug in the yellow connector into video IN on the Bose.
Feb 08, 2015 | Bose Av321 Series Ii Media Center For 321...
Vip211z...picture but no sound from HDMI
Not sure about that on satBox and tv, but you might be missing some settings about how the device reacts to that tv in specific.
Mar 11, 2014 | DISH Network Televison & Video
I have the dish network box which is HD although I can get a video feed on the television I get no audio
The first step you want to try is unplugging the receiver for ten seconds. After that check the cabling if you have component cables (red, blue, green, red, white) make sure the red and white are connected firmly. Also make sure they are connected right next to the red blue and green cables on the back of the TV. If you have an HDMI cable try connecting it to another port on the back of the TV. If that fails try replacing the cable.
Daniel Busa
DISH Network Customer Service
Jan 30, 2011 | Samsung PPM42S3 42 in. Plasma Television
How do i connect my samsung dvd recorder sh853m to my free sat box? Also is it possible to record a channel from free sat onto my samsung recorder while also watching a different free sat channel.
If it's a Standard-Definition (SD) FreeSat box then a SCART cable would be the normal method of connection to your DVD recorder. This would connect to the SCART/EXT OUT socket on the back of the FreeSat box and the SCART/EXT IN on the DVD recorder. However, this depends on whether your FreeSat box has multiple SCART outputs and whether you are using a SCART cable to connect to the TV.
If there is no spare SCART output socket on the FreeSat box, then you need to use an alternative connection which is common to both devices, i.e. co-axial, and make sure you are connecting from an OUT socket on the FreeSat box to an IN socket on the DVD recorder.
If you have a FreeSat HD box, then you need to connect it to the DVD recorder using an HDMI cable or another cable type that will carry an HD signal.
You will only be able to record from a different Satellite channel if you have a Dual LNB with 2 feeds to the FreeSat box. The LNB is the receiver that attaches to the arm on the satellite dish. You can determine whether you have a Dual LNB as you will have 2 cables from the Dish to the FreeSat box. They may be joined as one cable, but there will be 2 F-plugs (threaded co-axial plug) on each end.
If you don't have 2 cables then you will only be able to record the same channel as you are watching. To record another channel, you need a FreeSat box that supports this feature and each channel needs also a separate feed from the dish.
Hope this helps. If you need any further assistance please post back with the brand model number of your FreeSat box and details of the connections you are using between the FreeSat box, the TV and the DVD recorder.
Regards,
BElectric
Dec 29, 2010 | Samsung Televison & Video
My sons Sharp tv was working for dish but i was trying to make it work for a dvd i did something with the imput but i put it back on the right input and it still not reading the dish box works because it...
Make sure the input is hooked in properly first, also make sure it's coming out from dish to inputs on tv and turn tv to the input you are hooked too and then try turning on dish and off to see if you can see anything
Dec 07, 2010 | Televison & Video
I hooked my tv to my direct tv cable box and it keeps displaying no signal. Also, my remote control doesn't work.
Try hooking it to another tv and see if it works then, if not then it's not your tv but your satellite system cable not connected inside or outside, or your dish is not pointed n the right direction
Nov 30, 2010 | Televison & Video
How do you setup samsung tv to receive Dish network?
Hi my name is Roety,
I can help you with your issue ,
If the dish box is connected directly to the TV to the RF connector set the TV to channel 3
If it is TV # 2 you can use 60 or 73 (set also in main TV menu)
Or you can use the AV or component input/outputs/
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Dec 15, 2009 | Samsung Televison & Video
I just connected a new Samsung LED/LCD TV. I am
programm the remote to your tv by pressing the TV button till all lights light up at the top then enter your 3 digit tv code ( samsung codes are 738, 516 or 680 then press pound. this should enable you to controll power and volume, be sure to press sat to operate you dish recvr.
Oct 07, 2009 | DISH Network Televison & Video
Open Questions:
Symphonic WF803 DVD Player/VCR Logo
118 people viewed this question
Top Symphonic Televison & Video Experts
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
