Question about Mintek LCD TV Progressive Scan DVD Player
Mintek 265D dvd stuck in drive
Dvd stuck inside can't get it out--any suggestions?
Been pressing the eject button and it sounds like its whirring but then the whrring stops--and no disk comes out.
  • 4 Answers
I hope it is not too late to provide you the solution to your problem. I have posted on another site with my solution
but to save you the trip I will plug my solution.
My friend had the same problem.
She and her friends tried for two months but it was impossible
to physically pulled the stuck DVD out from the unit.
I was happened to be in the area and she asked me if I
can help her retrieved her movie DVD disc which was stuck inside the MinTek DTV-265-D.
GOOD NEWS! I was successful in getting the stuck DVD disc out of the unit and back into her hands.
Here is what I did to fix the stuck DVD problem:
I. Requirements
a. Tools:
Phillips Screwdriver (magnetic head will be the best)
Tweezers - Only if you don't have a magnetic Phillips screwdriver
Flashlight
b. Surface:
Large flat padded table because you will need it to lay the TV - flat.
c. People:
I did it by myself but having an extra hands is a plus.
II. Instructions
1. Disconnect power cord, power switch button "off" position, unplug cables and video cables from the unit.
2. Place the TV unit flat on the surface - screen on the bottom - Back cover side facing up
3. Back Stand: Remove the TV bracket stand in the back by unscrewing the 8 screws.
4. Back Cover: Unsecured the back cover panel side of the unit - 9 screws (After unscrewing
the screws you might need to use the tweezers to lift and remove the screws.)
5. Back Cover: Carefully lift (unlock) the back cover panel slightly away from the screen unit slowly
because it is wired to the circuit board. In other words, you can't remove it
completely which it is OK and it is not necessary. This back cover panel removal sounds
easy but the cable coaxial connector block it and making it difficulty.
Therefore, you will have to wiggle the cover until it is free and away from the coaxial connector
because you will need some clearance space to access the DVD unit.
6. DVD Unit: Unlock the DVD unit by unscrewing 4 (silver) screws.
7. Now you are set and ready to release your stuck DVD.
An extra hands will be nice to have but two hands is a requirements to do the next couple
of steps.
8. DVD Unit:
On the front side, locate the two (black triangle-shape or arrow shape) slot holders.
They are in a locked position.
Using your fingers lift and hold both sloth holders in the up position.
(You might have to raise these holders (up and down) several times.)
As you are holding up these slot holders please perform the next step (#9).
9. Power:
Push power button on the unit switch "on"
Plug back the power cord into the unit AC inlet
Unit Ready Light: "red" standby light is on
Remote Control: Press the power/DVD button - st the remote to DVD
Unit Ready Light: "Green"
** Important: Step No. 8 and Step No. 9 must be done simultaneously **
10. VIOLA! The DVD disc will automatically slide out of slot from the DVD unit.
William
Posted on Feb 15, 2008
You need to take the back off the unit and you'll see the DVD . Take the DVD out . You may damage the DVD ( scratch it) but don't disasemble the DVD carriage or you may not get it back together. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 06, 2008
6ya staff
SOURCE:
My dvd got stuck in the dvd player. ther may be another dvd in there. how do i get it out?/
Power the DVD player down and press the eject button. Try to remove the DVD carefully, without forcing it.
Mar 05, 2011 | Mintek DTV-233 23 in. TV/DVD Combo
When i press eject button cd drive is not
Sounds like the belt inside is broken or came off. Does te drive still sound like it is opening but does nothing? Also try using a small paper clip and push it into the small hole on te front of the CD-ROM that will at least open the drive manually and possible fix the problem if the device is stuck.
Apr 20, 2010 | LG GSA-H42N 18x DVD RW DL IDE Drive...
I have a dvd stuck in a toshiba tv dvd combination
Try a reset on ur tv,Like unplug ur tv an hoour.Replug it back.Should get power to the DVD port to take out the DVD disk.
Feb 08, 2010 | Toshiba 23HLV87 23 in. LCD Television
CD won't eject. I have tried the button on the drive and clicking the eject through the software. The light lights up and there is a whirring sound, but then nothing.
your cd rom tray is stuck inside may be due to a hardware error please take a paper clip and make it straight now insert this clip in a small hole located at the front panel of your cd rom drive..apply some pressure and the tray will be ejected/..
Thnx and i hope this helps
Please rate this solution
Jul 16, 2009 | Dell (0F146) Internal DVD Drive
Dvd tray stuck
The is a small hole next to the tray
Find a paper clip and gently puch the release the tray should open
LB
Sep 14, 2008 | Akai CFTD2011 20 in. EDTV-Ready LCD...
Controls Do not Work
Replace the Main Board. Take the back off and carefully remove the DVD. Avoid buying any TVs with a DVD or VCR in the unit.
Jul 03, 2008 | Mintek DTV-263 26 in. LCD Television
Mintek dtv-265-d no pictue
I had purchased Mintek Mdtv 265D , after Reaching Home (India) Tried to switch on the syastem but Screen Doesnot get on, as Per local expert the pwer supply having some problm, The same Set purchased in Month Sep 07 from Somewhere in US
Now the same is in India , how to repair and get rid of this problm
Jun 05, 2008 | Mintek DTV-263 26 in. TV/DVD Combo
Toshiba tv/dvd combo
is there a tiny little hole you can insert a paperclip into around the front of the cd.
if so use a large one if you have it , insert and press hard to eject.
if not then you will need help.
even if you get it out the eject motor belt is likely slipped or broken.
Apr 28, 2008 | Mintek DTV-233 23 in. TV/DVD Combo
On-screen Menu
Actually, it is not a Projection TV Problem. The problem is with a Mintek DTV-265 26" flat screen digital TV (not projection). I have not yet resolved the problem by unplugging the set, pressing the eject button and replugging in the set nor have I had any other suggetions. The manual clearly indicates Mintek DTV-265 26" (not Mintek DTV-263) but I feel they are very similar; however, the manual does not mention losing/restoring the on screen menu.
Feb 28, 2008 | Mintek DTV-263 26 in. LCD Television
Mintek 26 lcd hdtv, model DTV 265D
Have Mintek DTV-265-D that is frozen. Any suggestion to correct this problem?
Oct 20, 2007 | Mintek DTV-263 26 in. LCD Television
Mintek LCD TV Progressive Scan DVD Player Logo
227 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Ekse
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
