Question about Whirlpool Duet GHW9150P Front Load Washer
Whirl poolwasher f 02 and sud
CLEANED FILTER and ran thru with water still will not drain or spin
  • 2 more comments
  • sanitychek Jan 07, 2008
    i have the same problem. it is very frustrating. i cleaned out the debris in front of the pump, there were lots of coins! And a bunch of lint debris. Feeling good, put it all back together, ran an empty cycle of rinse and spin. everything worked fine. put clothes in there, and the same problem again, the f02/suds error comes back in the last 2 minutes. I opened up the bottom again and this time there was a big chunk of lint wrapped around some plastic. So more came out from the inside. I can't tell if it is a pump problem or a debris deep inside around the tub or someting problem. I can't even find where in the tub on the inside that debris like that could fit through? Anyway, Any further ideas would be great. I am not in a position to take the whole washer apart, so if it isn't something a lay person can attempt, please advise.
    Thanks!
  • Anonymous Jan 07, 2008
    Im having the same thing happen It is not even a year old, I cant afford another one so some, How can i get this fixed
    im having the same thing happen, what can i do to fix it
    My washer stops in the last 2 min , an f02 comes on and i can not get it to spin or drain, wehat can i do before i call a repair man out to fit it
  • 283 Answers
No need to take the entire machine apart. You can get to the bottom of the tub by removing the rear hose from the pump where it attaches to the tub. While it's off check inside it too.
Posted on Jan 07, 2008
Error message SUD and F21 even after unclogging the filter
Push the pause/cancel button twice to clear your message. Then run through a rinse/spin cycle. Next try a normal load without any detergent. SUDS is usually from too much detergent. If this fails, checked the hose for kinks. Check connections and if all that fails, you will probably have to replace the pump. Good Luck!
Feb 04, 2014 | Maytag MAH6700AWW Neptune Front-Load...
I have a Whirlpool duet front load washer model # GHW9150PWD. I have an error code of F 02 and SUD. I have so far cleaned the filter and the lines, replaced the pump, replaced the water pressure swith and...
6 - 1
DIAGNOSIS & TROUBLESHOOTING
SUDS DETECTION
During Drain Routine
During the Drain Routine, the water level is checked continuously. Normal drain will occur until the
pressure switch senses no water in the wash tub and there is no foam (suds). The drain pump will
operate an additional 15 seconds after the pressure switch reports no water or foam.
If the drain routine operates for four (4) minutes and the pressure switch senses any foam (suds) in
the wash tub, the Central Control Unit will start the "Kill-Foam" Routine. (See description of this
Routine below.) After the Kill-foam Routine is concluded, the Drain Routine will restart. If, after
four (4) minutes the pressure switch still senses foam in the wash tub, the Central Control Unit will
go into Failure Mode. The digital display will show, F02.
During Spin (Extract) Routine
During the Spin/Extract Routine the water level is checked continuously. If, during this routine, the
pressure switch senses the presence of foam (suds) in the wash tub, the Central Control Unit will
stop the drive motor and the basket will stop spinning. The electronic control will count the number
of spin repetitions that are attempted due to foam (suds). There are a maximum of three (3)
attempts for each Spin/Extract Routine.
Kill-Foam Routine
1.
The Remaining Time counter is stopped.
2.
The digital display shows Sud.
3.
The Drain Pump is turned OFF.
4.
The Central Control Unit will fill the wash tub with 1 gal. (4 L) of cold water.
5.
While the tub is filling the basket will tumble 1 sec. ON/15 Sec. OFF.
6.
Once the tub is filled, the drive motor will turn OFF and the basket will rest without any
movement for five (5) minutes.
7.
After the five (5) minute rest, the remaining time counter will restart and the digital display
will show the remaining time left in the routine.
NOTE:
If the Kill-Foam routine was initiated during a Spin/Extract Routine, the tumbling action
will be reduced to a cycle of 3 sec. ON/13 sec. OFF. If, at the end of either the Drain or Spin/
Extract Routines, a suds condition still remains, the digital display will show Sud.
Sud will also be displayed for a short period at the end of a cycle, if a Suds condition was
detected during the cycle. This will alert the consumer to reduce the amount of detergent in
subsequent uses MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 31, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Getting F 02 error code then when I clear it it says SUDs when there are no suds. Take two days to wash one load of clothes!!!
Hello :)
Check the drain hose and make sure it is not plugged or kinked,
check the electrical connections at the pump.
Check the drain pump filter.
May 22, 2017 | Kenmore HE4t 3.8 Cu. Ft. Plus Front Load
My whirl pool duet sport keeps having an error message of f21 and 5d. i read that it means the water is not draining right. what can i do to fix this?
F21 means to a long drain.
Basically means that water is not pumping out quick enough. If all the drain lines have been checked for blockages and restrictions the manufacturer recommends the pump is replaced. Some times the impeller can become damaged or the motor which can cause the pump to work slower then it should causing this error code. If you took off the hose from the tub to the pump and found nothing then I doubt there is a blockage in the drum (it would have moved into the drain filter).
Sd or 5d error SUDS LOCK (OVERDOSE OF DETERGENT DETECTED DURING THE WASH CYCLE)
If suds are detected continuously by the pressure switch during the drain or spin phases, the washer will fill 4 liters of water and during 5 minutes the unit will rest without tumbling, the water will be drained and it will try to spin or drain again.
If too much detergent was used:
- Run the unit through a RINSE/SPIN cycle.
- Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test or any cycle.
Hope this helps.
Aug 15, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
I have a kennmore elite front loader washer and have taken off the front bottom cover and cleaned out the drain (a pen, some coins and a clear ball) I took the hose off completely by loosening the coil...
try unplugging it and lkeave it unplugged for at least hour that should reset it ,sud of course refers to low water flow into pump but i am sure that has been resolved
Jul 20, 2011 | Kenmore Elite 45986 Front Load Washer
Final spin cycle I get sud error code or f2, water mostly drained but no spin. When I restart the spin cycle just starts to spin then stops, sounds like it drains some more water then makes a small...
Check the drain hose and make sure it is not plugged or kinked • Check the electrical connections at the pump and make sure the pump is
running. • Check the drain pump filter for foreign objects • If the above does not correct the problem replace the pump
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
Feb 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer SUD F-02 problem: Recently I noticed that the water was not draining inside the washer once in a while. Starting last week, I heard the beep sound and it told me it is F-02. After...
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet HT washer. I keep getting the F 02 code and SUD right after. I have cleaned the filter and drain hose. It didn't fix it. I replaced the pump this afternoon. That didn't fix it. I...
Hi there I have found the code for you and hope this helps?
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Thank you for writing to fix ya
Feb 12, 2010 | Washing Machines
What does the "sud" message mean?
hello fo2 means if the drain time exceeds 8 minutes the water valves are turned off and f/02 flashes. things to check / check the drain hose for any kinks and blockages check the electrical connection to the pump make sure the pump is running / check the drain pump filter make sure its not block if these do not sort the problem replace the pump. to clear the display press pause and cancel to clear good luck
shaun
Mar 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Duet washer doesn't run through the entire spin cycle on heavy duty setting. Clothes come out of washer, naturally,WET!!!!!!!!!!!!!! Seems to spin out better on the normal cycle. spin cycle dosent...
If the drain time exceeds eight minutes, the water valves are
turned off and “F/02” is flashed. Press PAUSE/CANCEL two
times to clear the display.
NOTE: After four minutes the “Sud” error will be displayed,
then four minutes later the “F/02” error code will be
displayed.
Possible Causes / Procedure
or kinked.
3. Check the electrical connections at the pump and make
4. Check the drain pump filter for foreign objects.
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
61 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
