Question about Nova Development Photo Explosion Deluxe for PC
Photo explosion closing
My photo explosion keeps closing when i hit import from my scanner...why would that be?
    Genius:
  • 1,067 Answers
Glitch in program usally do u have latest updated verison of photo program and latest scanner driver bestthing u can do is scan your pics to hard drive jpeg then editthem in photo explo if u need more help u can chat live with me ill be on all night thx nick
Posted on Jan 06, 2008
6ya staff
SOURCE:
MPEG VIO Driver Error photo explosion special edition 3.0
How to correct a Load MPEG VIO Driver Error in Windows Vista.
If you are experiencing this issue with Windows Vista, please follow these directions:
Note: These steps are only for Windows Vista. If you are experiencing the problem on Windows XP, please see the directions found here: KB Article 1469
1. Uninstall Photo Explosion 3.0.
2. Reinstall Photo Explosion 3.0.
3. Restart the computer.
4. Download the Vista update for Photo Explosion 3.0 from the following link:
http://www.novadevelopment.com/Support/Updates.aspx
Note: Please make sure you download the correct one for your version of Photo Explosion 3.0. If you have the Deluxe version, download the Deluxe update. If you have the regular version, download the non-Deluxe update.
5. Save the update to an easily accessible location, such as your Desktop.
6. Once downloaded, go to where the update was saved and double-click the update.
7. After installing the update, you should no longer experience this problem.
Note: It is extremely important that you do not run Photo Explosion until you have restarted the computer and installed the update. If you run the program before installing the update, you will need to start the steps over from the beginning.
This comes directly from the Nova FAQs. Hope this helps!
Jun 30, 2010 | Nova Development Photo Explosion Deluxe...
Problem loading photo explosion delux version 3 disc 1
You can right-click on the program's setup.exe, select properties, then compatibility and set it to windows XP
then try to install it again
Dec 15, 2007 | Nova Development Photo Explosion Deluxe...
Photo explosion 4.0 project studio. When I create
I kind of doubt this is your problem, but try and save the file by using the "save by a different name option." Then click options and slide the file size to large. Make sure you have your color setting set to rbg, not cymk. The channel should be set to 8 bits, not 16. I am not sure where that selection would be made in 4.0, but jpgs are not compatible with 16 bit channel. If you can't find the setting, check the help file.
Two questions: 1 Can you open any pdf and jpg files in Photo explosion, and 2 can you open the files you have created in photo explosion in another program?
If you can't open any jpgs/pdfs with any program, the problem is probably with your operating system. If the problem is only with photo explosion created files, and they can't be opened in any other program, it may be the "plug in." That is the piece of software required to produce the file. A viewer is also required. If you can open the jpg in another program, that would indicate photo explosion. The plugins that are loaded into the program should be listed, possibly under tools. You can try to update/reload these.
You have not indicated your operating system. This is important to correctly answer more complicated issues. For instance, if you have Vista 32/64 bit, your software has to be compatible and set to the right version. Because Vista is prevalent, I looked to see if it is compatible. Unfortunately, Nova recommended buying an update for the 32 bit version and had no info on the 64 bit. Somewhere on the photo explosion box there should be a small label telling you what it is compatible with. I hope that if this was not helpful you will leave me more info and answers to the above by writing a comment. I can get back to you with more specific advice.
May 06, 2010 | Nova Development Photo Explosion Deluxe...
C:Program Files/Nova Development/Photo Explosion
try uninstalling the software,disconnect from the net,and then disable your anti-virus.then reinstall the software. This sounds like you might have a corrupted install
Oct 26, 2009 | Lexmark All-in-One Printer with PictBridge
How do I put a person from one photo into another photo with some one? I have a new Photo Explosion Deluxe.Thank you. Bud
For shifting embeding one pic into another you need to first crop the initial image which you wish to move. While moving you shall keep in mind about the back ground in both the pics hence you should select the persons pic whose pic which you want to move very closely through the body. For that you can use either wand which would not be of too much help you will have to manually select the area for cropping so increase the visual limits of the pic and use the select manually tool and use control or alt key for minor adjustments. After selecting the image just copy and paste on the new picture and move as per your requirement.
Jun 15, 2009 | Nova Development Photo Explosion Deluxe...
My photo explosion deluxe in windows xp does not run on vista
According to their website: http://www.novadevelopment.com/Products/us/prw/sys_req.aspx, pdw works with vista. Can you tell me what exact error you are getting?
Jan 02, 2009 | Nova Development Photo Explosion Deluxe...
Printer won't scan a picture
I had the same problem, but I was able to scan my first photo today. If you are using Windows Vista and have Windows Photo Gallery on your system, you should be able to scan your photo/documents. Open Windows Photo Gallery 1. Click File, and then click Import from Camera or Scanner.
2. In the Import Pictures and Videos window, click the scanner that you want to use, and then click Import.
The rest should be self explanatory. Good luck!
Jun 17, 2008 | Canon Pixma MP500 All-In-One InkJet...
Won't scan
You have to go to Windows Photo Gallery. Click on "File". Select "Import" and it will prompt you from there
Dec 31, 2007 | HP PSC 2410 All-In-One InkJet Printer
Photos
It will work only on Basic WIA drivers..(windows image acquisition) untill lexmark will make software, Its possible that they might not.
SCAN from WINDOWS Photo Gallery is possible...
Open windows photo gallery>Click File>Click Import from scanner>Import & thats it...
The scanned image will be saved on pc >My document/scans automatically & then later if u want to change the formats thats possible using 3rd part softwares
Dec 20, 2007 | Lexmark X6170 All-In-One InkJet Printer
Nova Development Photo Explosion Deluxe for PC Logo
85 people viewed this question
Top Nova Development Computers & Internet Experts
Peter Dragonetti
Damen Wong
Damen Wong
Are you a Nova Development Computer and Internet Expert? Answer questions, earn points and help others
