I could not find any product that would fit a SFF case. The best suggestion i have for you is to get the riser card adapter that will fit standard PCI cards in the Dell Optiplex 7xx models. here is the link and partial discription.
The Dual Full Height Riser from Dell™ enables you to fit two PCI card in its slots. This product has been tested and validated on Dell systems and is supported by Dell Technical Support when used with a Dell.
http://accessories.us.dell.com/sna/products/Controllers/productdetail.aspx?c=us&l=en&s=dfh&cs=22&sku=430-2598&~lt=popup&~ck=TopSellers
I hope this helps you. Best Regards, -md
Comments:
Nov 10, 2009
- After i kept looking i found this adapter for you. Hope it helps. Best regards, -md
Low Profile FireWire 1394 PCI Adapter
Two external and one internal IEEE 1394 (FireWire) ports support DV camcorders, cameras, hard disk drives, removable drives, scanners, printers and other 1394 audio/video devices including TV, VCR, DVD with data transfer rates up to 400Mb/s
Features:
* Regulatory approval(s): FCC Class B (DoC) & CE
* OS support: Windows 98SE/ME/2000/XP/Server 2003
* Chip: TSB43AB23 (TI single chip)
* Bus type: 32-bit PCI
* Port type:
o Two external IEEE 1394 400Mbps ports (6-pin connector)
o One internal IEEE 1394 400Mbps ports (6-pin connector)
* Dimensions:
o PCB: 119.91mm (L) x 64.41mm (H)
o Bracket: 18.42mm (W) x 79.20mm (H)
* Compliant with IEEE 1394-1995, 1394a-2000 and OHCI 1.1 standards
* Fully interoperable with FireWire and i.LINK Implementation of IEEE Std 1394
* Compliant with PCI Plug-n-Play 2.2
* Provides three 1394a-2000 fully-compliant cable ports at 100/200/400 Mbits/s
* Hot-swapping feature allows you to connect/disconnect devices without powering down the system
* Adds 3 IEEE 1394 ports to your PC (2 external, 1 internal) for high-speed I/O connection and supports up to 63 devices
* Manufacturers Life Time Warranty
The SIIG Low Profile FireWire PCI Card package contains:
* Low Profile FireWire 1394 Adapter
* Quick Installation guide
System Requirements:
* A Small Form Factor PC with:
o Available PCI slot
o Windows 98SE or later
