Question about Splendide 6200
Broken door this is a clost door. the door knob. can not unjam the door hinges thank u
0 characters
1 Points
How do I repair/replace a broken door?
Hello there, you will need a new hinge and probably the inside round piece of the door. Can you upload a photo? Please indicate the
E-Nr of the machine. You can find it on the label around the door and/or at the back of machine.
Jul 02, 2015 | Bosch Washing Machines
The hinge of the washing machine has broken - Creda W100FW
The door hinge block has fallen inside the front of the washer.To retieve it, tilt the washer back, and you should find it at the left hand side.
Remove all screws securing 2 parts of door together, prise apart with a screwdriver or similar, and the door will come apart.
You can now access the hinge and all other partsd inside the door.
Trust this helps.
Nov 28, 2009 | Creda W100FW Front Load Washer
Want start unless you slam lid or push start knob in and out
HI, Check and see if the door hinge screws are tight. Sometimes the hinge loosens and the lid switch will not activet properly. It the lid is tight, you might have a lid switch going bad. The lid switch is located under the control panel. There is a screw in each corner of the control panel in the back side. Loosen these screws and lift the control panel up and it will rest on the hinges.
Ths lid switch is to the left and should have three wire to it. Parts# 8318084
I hope this helps you. If I can assist you further or you need a place to order the lid swtich, please give my web site a chance at
May 22, 2009 | Washing Machines
Need to locate parts for purchase for old Admiral washing machine. you will find your hinge here
Apr 14, 2009 | Washing Machines
Starter Knob broken
go to sears .com,click parts put in your model number(should be inside the dryer door)and get your part.or repair
Apr 09, 2009 | Kenmore 98702 Stacked Washer/Dryer
Broken door hinge replacement on Hotpoint Ultima
Remove all the screws securing the 2 door halves together, and gently prize apart the two halves with a screwdriver or similar, be careful not to drop the door glass.. You will probably be better off removing the door from the front of the m/c altogether.
Replace broken parts as req'd.
Plz rate my solution
Dec 27, 2008 | Hotpoint Ultima WD72 Front Load...
Door hinges broken and door fell off
yeah very easy and it should only cost at most about £10 undue the old hinge with the 2screws now the door will have two little covers that held the old hinge in place take these out and make sure u get the broken pieces out of them once u have the new 1 put it on the washer and screw down first and then place the covers on the ends of the hinges and put the door in place now redue the screws on the door
Jun 01, 2008 | Candy CN146 Front Load Washer
Splendide 6200 Logo
21 people viewed this question
Top Splendide Washing Machines Experts
Doug Adams
Doug Adams
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
