Honeywell CT87B ROUND HEATING&COOLING MECHANICAL THERMOSTAT - WHITE Heater
Problem for Honeywell CT87B ROUND HEATING&COOLING MECHANICAL...
Hi There,\r\nI have an Ideal Response 120 Combi .
By thomaswj_loc on Nov 10, 2009
Hi There, I have an Ideal Response 120 Combi Boiler.
Each day the water pressure falls to 0 on the pressure gauge. In order to get hot water and Cental Heating I increase the pressure to 1.5.
The Hot water works ok however the only way I can get the CH to work is to press the Overide. (the remote controll will not turn on the CH) The Red light on the Overide(alarm) is constantly on. When I turn on the CH the water pressure increases as the system gets hotter.To eleviate this I drain the water from the nearest radiator. This brings down the water pressure. Once the CH is turned off the pressure is lost. There are no leaks to the system or radiators.
Can you advise what is wrong.
Thank you
Popular Solutions for Honeywell CT87B ROUND
Questions and Unsolved Problems for Honeywell CT87B ROUND
Do you recommend Honeywell CT87B ROUND HEATING&COOLING MECHANICAL THERMOSTAT - WHITE Heater?
Answer
Answer
my under floor heating is working , but all of a sudden the rooms have all gone cold and the hot... (More)
Answer
My Gas furnance was lit earlier today after several days being off. The Furnace will not re-light.... (More)
Answer
combi boiler ravenheat he85aaa turn boiler on hot water or raidiators burner lights, steam comes out... (More)
Answer
my heater blower is blowing out cold air not hot but the expansion tank is b ubbling
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Honeywell CT87B ROUND...:
Top Heater Experts
Rank: Guru Guru
Solutions: 1220
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Heater Experts
Top Heater Repair
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
