Fuji FinePix Z1 Digital Camera Logo
Posted on Nov 10, 2009
BATTERY DEAD WONT CHARGE NO LIGHTS ON CHARGER BASE
THE CAMERA WENT DEAD DUE TO LOW BATTERY. I PUT IT ON THE CHARGER AND THE LIGHTS ON THE CAMERA WONT EVEN COME ON I AM CHARGING IT ON A COMPUTER. WHAT CAN I DO TO FIX THIS PROBLEM? NEW BATTERY? NEW CHARGER? PLEASE HELP ME
5 Related Answers
Anonymous
  • Posted on Sep 26, 2008
SOURCE: Fuji Fine Pix Z5 battery won't charge
I had the same problem!! Try flipping the battery around and then charging it. It worked for me! Hope this helps!
Anonymous
I looked up this question with the same problem and while the battery was placed in with the right side in, the three metal tabs weren't on the right side with the three metal chargers- so I had to spin it around the other way...i hope i'm explaining this right...now it's charging! I am so glad. This camera is excellent.
A
Anonymous
  • Posted on Oct 01, 2008
SOURCE: Battery Dont Charge
jpierre's solution (in another thread) was right on the money. Touch the positive (+)end of the 9v battery to the positive (+) end of the camera battery.Leave them touching for a few seconds (10 seconds should be more thansufficient). Seems these lithium-ion batteries are subject to a'digital memory.' Subjecting it to a volt surge almost three timeshigher seems to clear it.
http://www.batteryuniversity.com/parttwo-34.htm
In short, it works like a charm.
Anonymous
  • 7 Answers
  • Posted on Aug 05, 2009
SOURCE: My Casio Exilim EX-S880 wont turn on. Battery is
I found this while trying to solve my exact same problem.. It worked for me after about 7 times. Some other people on the site said it worked for them after 20 times. Good luck!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
david
  • 244 Answers
  • Posted on Jan 03, 2010
SOURCE: fujifilm finepix v10 does not turn on. when
Fuse F351 has possibly blown on the board. It is a 2.5A 32v UL type surfacemount fuse which is soldered to the board. The fuse has a coded letter on it for identification. Recomend you find someone who knows electronics to repair
2answers
My one camera wont work anymore
Check camera charger output voltage with multimeter. If there is no problem with charger; charge camera battery to full charge. As a next step; check your camera battery voltage with multimeter. If battery is dead, replace battery with new one.
I Have a Fujifilm Finepix J37 that wont turn on, I assumed that the battery had run down so put it on charge and no lights came on, usually it lights up on the back of the camera when its charging! Faulty...
hmm i have the same problem with mine.i got a replacement battery and it worked fine for a few days but then went back to the way it was. so i'm thinking the problem is with the camera itself. how long have you had the camera for?
2answers
Camera wont turn on.
try replacing the battery. Check best buy, radioshack or other camera dealers for a battery. Possible deadcell battery. These lith-ion batteries die with no warning. If there is no change, the camera is defective!! hopefully htis helps
Low Battery, Connected car charger, now is dead
May be the battery won't have charge, keep 1 or 2 hrs continues charges, and if it is not working then you have to replace the battery set full.
3answers
Screen wont come on
Does it only light up when you adapter is plugged in? If so try taking out the battery and making sure it is in correctly. Press the power button under the screen on the side if the unit and the middle circle in the directional key pad, there should be a menu that comes up.
Battery Dont Charge
I had the same problem. I had a 1 year warranty, so I called 1800-435-7732 and they sent me a new battery within 5 days. I just received it today and it works perfectly. Hope this helps you! =]
Battery Dont Charge
Battery problem or camera problem?
A new battery should help you to solve this problem.
1helpful
2answers
Vtech phones loosing connection to base
You are pretty close to the solution. The problem is the charge detection in the handset. All handsets on a cordless phone detect the battery level with an hexadecimal value in the memory. Each hex value equal a volt value of the battery. EX: 3.5v = 9B
3.6v = 9C 3.7v =9D etc... The problem is the hex value in your defective handset are all mess up. So 9B is not 3.5v anymore. Then your handset could last 1hr after foul charge or doesn't alert you before the phone goes dead due to low BAtt.
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
