Question about Sony Cyber-shot DSC-W100 Digital Camera
Setup and loading pictures..
Loaded on computer with disc. When you click on import media files where it says select the drive reads: Cannot find source media for importing..
A little stupid here any help would be greatful!
    Problem Solver:
  • 13 Answers
My computer makes the windows uploder pop-up. when it pops up make sure it says "cyber-shot photo viewer" or something of the like.
then right click on the little binoculars in your taskbar (look down at the far right corner where all those little icons are, it's called "cyber-shot viewer media check tool"
right click, import settings, then specify a file to drop the images.
thats the only thing i can think of. call sony if that doesn't help. good luck
Posted on Mar 04, 2008
How to boot with usb flash drive. detailed please, I'm trying to many diff ways nothing working, bios is the only thing on comp.
It is possible to boot from a USB drive....but only if the USB drive has been formatted as bootable, in the same way that OS CDs and DVDs are bootable media. You have to have an operating system either on the hard drive or on the flash drive in order to boot the computer. The BIOS is simply a "Basic Input-Output System" that interfaces the computer hardware to the OS, whatever media it is on. That is why you have to select the boot device and the boot device priority in the BIOS during setup, so it can direct itself to the bootable OS. Once you have installed an OS, then all will work fine. Until then, you will continue to have issues. Normally, with Window-based systems (you don't say what OS you are trying to use), you would insert the bootable Windows setup disk in the CD/DVD drive, ensure the BIOS was set to boot to CD/DVD first, and start the computer. The windows setup file would load itself and start the OS install process. It may even be necessary to partition and format the hard drive during this evolution, but the setup program would lead you through that as well. I have seen Windows setup files loaded to USB sticks, but they require a special process to generate so the BIOS sees the USB as bootable.
Jun 26, 2015 | ASUS Computers & Internet
How to Load a Device Driver
<span>Instructional step<br /></span> <ol> <li> Enter the device command into the "config.sys" file for older Windows operating systems. These commands can define whether the device is loaded normally or if it is to be loaded into upper memory. The older operating systems gave lots of flexibility to the user as to how the drivers were loaded into memory and in what order they loaded.<br /> </li> <li> Right click on "My Computer" icon on the desktop. Select "Properties." Select the Hardware tab and click on "Device Manager" to open up the window that shows all the devices connected to the computer and allows access to the drivers for these devices.<br /> </li> <li> Locate the driver that you need to install either from <a href="">the Internet</a> or on a CD or other media that came with the computer from the manufacturer. Look at the Device Manager screen and find the device that has a yellow exclamation point on it indicating that there is a problem with the driver for that device.<br /> </li> <li> Click the icon (right click) and select "Update Driver." Read the Hardware Setup Wizard window that opens and follow the directions carefully. When asked to have Windows find the driver select "No" and then browse to the location of the driver that you have. Let the Hardware Setup Wizard install the new driver and close the Device Manager.<br /> </li></ol>
on Oct 29, 2010 | Computers & Internet
How to disable Autoplay of Audio CDs and USB Drives in windows
All recent versions of widows contain features called AutoPlay and AutoRun. AutoPlay lets you choose which program to use to start different kinds of media, such as music CDs, or CDs or DVDs containing photos. For example, the first time you try to play a music CD, AutoPlay asks which media player you want to use, if you have more than one installed on your computer. You can change AutoPlay settings for each media type.Autorun is the technology used to start many programs or enhanced content (such as videos on a music CD) automatically when you insert a CD or USB drives into your computer. This is different from AutoPlay, but the result are the same, when inserted, the CD or USB drive starts automatically, using a particular program. Autorun is incorporated into the media types that use it, and you can't modify it.
When a disc is inserted or a drive is connected to your computer, Windows looks in the root directory of the disc or drive for a file named autorun.inf. If found, Windows executes the instructions in that file. ( whether it be start the music or install the virus.)
For example, an autorun.inf file on a CD might contain a line that reads open=setup.exe. This tells your computer to launch a setup program as soon as the CD is inserted into the drive
Removable USB/thumb drives use the Autorun feature to load files when the drives are plugged into the USB port. Malware exploits the Autorun feature to spread from thumb drive to PC. Disable the autorun feature to prevent malware from spreading.
For XP users:
1.Click Start and then click Run. Type gpedit.msc and click OK. The Group Policy window will open.
2. In the left pane, double-click Administrative TemplatesIn the right pane, double-click System, scroll down the list and double-click Turn Off Autoplay
3.In the Turn Off Autoplay Properties window, select Enabled. From the dropdown next to Turn Off Autoplay on, select All drives and then click OK.
4.Exit Group Policy by selecting File, then choosing Exit from the menu.
on Sep 17, 2010 | Computers & Internet
How do I load the software? When I put the disc in there are no instructions on how to load it into my computer
There should be a setup.exe or install.bat file located usually at the root folder, if installation doesn't start automatically, maybe you have disabled auto play for your CD/DVD drive, to enable it, please go to control panel, look for Auto Play feature and select the action to take according to your disk type (data,media).
Feb 23, 2011 | Copenhagen TA-454 256 MB MP3 Player
When you load an OS and you press F6 to load raid or SATA drivers, where is this information stored? Is it on the bios, CMOS, or on the hard drive that you are attempting to install?
Actually, the RAID and/or SATA drivers to be loaded using the F6 option have to be provided by you. They can be loaded from a USB flash drive or an external floppy drive.
The process is as follows:
1. You proceed to your motherboard/hard drive manufaturer's support site and locate the driver for the hardware you need it for.
2. You put that driver on one of the two media devices (floppy or flash) being sure you've carefully read the instructions for loading that driver in such a way that Windows can receive and install it.
3. You attach that media to your computer before you boot into the install disc and when prompted to press F6 do so. Shortly after you'll reach the point where the Setup asks for the RAID oe third party driver and you need to direct it to the driver by browse and choose the media if it doesn't find it by itself.
4. Highlight the driver in the selection window and click/hit enter however prompted to do so.
If you've executed all steps correctly, the driver will load and setup will continue an compete successfully.
Best Ragards and Good Luck!
Aug 26, 2010 | Asrock K7VM3 Motherboard
My Sony vaio came already loaded form Sony, after
go here for a how to: 0 128704615
Or try this-
  1. Place a blank media disc into the appropriate optical drive.
  2. Click the Start button and in the Search programs and files field, type system repair disc , and then press the Enter key. LoadImage('png60589.png','Block BorderSolid','','','Search programs and files') png60589.png
  3. In the Create a system repair disc window, click the Create disc button. LoadImage('png61020.png','Block BorderSolid','','','Create a system repair disc') png61020.png
    NOTE: In the Drive field, the appropriate optical drive should have been displayed automatically. If your computer has more than one optical drive capable of burning to blank media, you can click the down arrow and then click to select a different drive.
  4. When the Using the system repair disc window appears, remove the disc from the optical drive, follow the on-screen instructions to label the disc appropriately, and then click the Close button.
  5. In the Create a system repair disc window, click the OK button.
Jun 13, 2010 | Sony VAIO PCV-RX500 PC Desktop
I have a Toshiba Satellite Pro 4600. The DVD drive has stopped working, It works correctly with a lens cleaner disc. but when I try any other disc I get the following message '' windows cannot read from...
Load a CD in the drive then go to My Computer and right click on the drive letter. Now click on explore and see if it opens the folders on the CD. If it can not read the CD files then you may need to replace the drive. Check that the driver is properly loaded and windows recognized the drive properly. Control Panel-System-Hardware-Device Manager then select the CD Drive to see the status of the driver. If it has an error you may need to replace the driver. Another thing to do is go into the Bios setup when starting the computer and see if the Drive is recognized properly. While you are in the Device Manager look at the tab for "Region" which should be set for Region 1. If it is not set for 1 it would cause this problem. Good Luck
Dec 09, 2009 | Toshiba Satellite Pro 4600 Notebook
I want to down load a song on my computer to a disc. How do I do this?
* First you should have a CD/DVD Burner on your computer (ordinary CD player would not work).
* Load the blank disc into the DVD burner
* Open the folder where the song is, highlight the song by clicking it once.
* Click on "copy this file" and then select the DVD drive.
* Then the file should start downloading.
Have a great day!
Sep 13, 2009 | Dell Computers & Internet
Cant get programe disc to load
Goto "my computer" -> right click on CD drive/DVD drive icon and select open. you will find all the contents present in the CD. Browse to appropriate folder where your program is located and run its setup.exe file to start installation. this is how you can do it manually. I hope this solves your problem.
Sep 09, 2009 | Computers & Internet
I have a Nikon Coolpix P2 camera that I love. I used to have Picasa 2 software loaded and it automatically detected when I attached the camera to a USB port. I've accidently upgraded to Picasa 3, and that...
It's probably because Picasa 3 is not your default import program for photos. You can fix this by:
In Windows XP, your default import setting must be adjusted on a device by device basis:
* Connect the import device (your camera or card reader) to your computer.
* Double-click My Computer on your computer desktop.
* Right-click the listing of your import device.
* Select Properties.
* Click the Autoplay tab.
* Select 'Pictures' from the content drop-down menu.
* Choose from two possible actions:
* Select an action to perform: Select an application to handle import by default each time photos are detected on the specific piece of hardware.
* Prompt me each time to choose an action: Choose an import application each time you attach your hardware.
* Click Apply.
* Click OK.
Windows Vista
Windows Vista allows you to set a global import preference for all photo or videos files.
* Click Start > Control Panel.
* Select Autoplay.
* Under 'Picture' or 'Video,' select your default import program.
* Click Save.
Dec 28, 2008 | Nikon Coolpix P2 Digital Camera
Sony Cyber-shot DSC-W100 Digital Camera Logo
638 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
