Question about Dell Latitude D600 Notebook
Laptop not powering on
Hi
I have a Dell Latitude D600 laptop and it was working ok a couple of days ago but know it does not power on. When I press the power button all I notice is the battery LED light flash red for a split second.
I have removed the RAM and wireless card and still get same problem. I read somewhere that it might be the processor, so I replaced it from another laptop (same model and make) and I still get same error.
Any ideas, help would be most appreciated.
  • kinatu28 Jan 08, 2008
    Thanks for your post. No the battery light does not light up when I unplug the AC adaptor. I have tried removing the battery and also tried powering on using just the adaptor. I still get the battery LED light flashing red for a spilt second. The other interesting thing I noticed was when I removed the battery and try to power on using the AC adaptor, the green LED light on the adaptor turns off and there is no power coming from the adaptor even if I plug the adaptor into a working laptop. The AC adaptor is not faulty nor is the battery as I have tested them on another laptop and that works fine.
  • dayplayer Jan 18, 2008
    Same problem here - D600, no battery, connect using AC adapter from my Inspiron 6400 and it kills the adapter. Have to unplug before it will work again. I suspect a short in the MB connector.
    Problem Solver:
  • 5 Answers
When you unplug the ac adapter does the battery light lit up when you try to power on? If it does.. does the battery have life?? Well the next step is to remove the battery and try using only the AC adapter and see if it stays on.. if it doesn't they your power connection could be loose from the motherboard... B/C in general the LED for ac adapter should go on when you plug it in.... Well try that and see what happens..
Good luck..
Posted on Jan 06, 2008
    Problem Solver:
  • 8 Answers
I only could offer a dell laptop battery on-line store for you
Posted on Mar 20, 2008
May be is not the battery problem i think,but i could recommend a dell laptop battery on-line store for you.
And for your trouble,I have never come up against
    Novelist:
  • 188 Answers
I bet this is a motherboard short not just the power jack. If you use your laptop with a D series port replicator or docking station (make sure your adapter is a PA-10 90 watt adapter or it wont work!) and the light on the adapter goes out then its NOT the power jack its a bad motherboard. If seen a lot of these D600s die this way. I am seeing D600 motherboards on ebay for about $150 though if you like the laptop it might be worth it...
Posted on Jan 24, 2008
6ya staff
SOURCE:
DELL LATITUDE D600 USB PORT NOT WORKING
You can solve this issue by installing usb 2.0 driver in your DELL LATITUDE D600 laptop find Blow Drivers Download Link:
.DELL LATITUDE D600 Drivers Download Link
Feb 05, 2010 | Dell Latitude D600 Notebook
Dell latitude d600, mic works sometimes
The Mic is on the same board that the power button is on.. there is a problem with this board,, the problem is were the power button board plugs into the main board....... when you push down on the power button your affecting the mic''s conection to the main board,, {Its a bad plug}
The Mic is found next to the power button.. to the left look for a small pinhole,, ....try pushing down to the right side of that.. test Mic when you do this,,,
You need a new main [mother] board to fix
Sep 25, 2009 | Dell Latitude D600 Notebook
Dell latitude d600 will not turn on / power on
it means not charging the battery pack, did you check the dc jack connector, or the.
charger check it if working properly, if the same problem open the laptop then check the baord
thanks
Jul 12, 2009 | Dell Latitude D600 Notebook
Power button
try one step if that doesnt work contact the dell tech on 18006249896 it could be a major hardware failure
remove the battery and also the power cable and hold down the power button for 10 sec and than connect the battery and the power cable and start the pc that should work
Jan 12, 2009 | Dell Latitude D600 Notebook
Dell Latitude Notebook D600
the laptop probably overheated.
I would get a cooler for the laptop they sell them at wal-mart or stores such as that one.
It's a small thin table like that the laptop sits on and it has 2 fans pointing up at the bottom of the laptop.
Unplug the power supply then hit the on button and try it if it don't work unplug the battery then try that.
Happy Holidays
Dec 27, 2008 | Dell Latitude D600 Notebook
Dell latitude d600
he battery is bad or a bad wire or take it in
Nov 03, 2008 | Dell Latitude D600 Notebook
From the keyboard how can i adjust dell latitude D 600 brightness
Hold down the Fn key and press the up arrow several times until it tops out. By default, if you are running on battery power, it dims the display to conserve power.
Oct 23, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
D800 will not even boot
remove the battery from the system and try to power on the System with the AC adapter connected. its only to check whether the system is receiving the power .
Also press the Fn key holding it down press the power button and release both the buttons , look for the LED codes and do let me know abt it
Apr 21, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
539 people viewed this question
Ekse
Clive
Clive
Alun Cox
