Baseboard heater I have 2 baseboard heaters in my basement one with thermostat and one that doesnt but it wired to the one without. The problem is that the one without the thermostat wont shut off even when the thermostat unit is turned all the way off.
  • Lemieux66 Jan 06, 2008
    I figured it was something like that.I'll check it out, Thank you!
  • 579 Answers
Has it always worked like this? It seems like the wiring connection at the thermostat must be wrong for the one to work and the other one not to. Check the connections at the thermostat to make sure both heaters are wired to the output of the t-stat..
Posted on Jan 06, 2008
I have a base board heater in the basement. It's never been connect up the wiring is all there from the breaker box to the heater,it has 1blk.1white and the ground. heater has 1blk. 1 red & therostat
You need to take a meter and see if you have 220 volts between the black and white. if you do have 220 then hook white wire to the red on the on the thermostat and the black to the black wire on the thermostat. on the other side of the thermostat hook the red and black to the red and black to the heater
Jan 01, 2012 | Marley Electric Hydronic Baseboard Heater,...
Im hooking up a base board heater for the first time with a non programmable thermostat that has 2 black wires on the thermostat. I'm hooking it up to a two pole breaker that means back wire to top screw...
Hello there
It sound alright but You should draw out a wiring diagram on paper first before you tackle the job that way you know you're doing it right.
Good luck Dickson
Nov 04, 2010 | Fahrenheat Electric Convector Baseboard...
I have a large room in my basement where I would like to install four Marly 58" baseboard heaters to work off one thermostat. The units are rated at 1250 watts each for a total of 5000watts. I plan to...
Using the equation I = P/E where "I" is Amps, "P" is Watts, and "E" is voltage, we find that your 5000w circuit will have an Amperage of 20.83. A 22 amp tstat will work, it will just leave you no room for surges. I would suggest splitting the baseboard and using 2 thermostats. Hope this helps
Aug 10, 2010 | Marley Electric Hydronic Baseboard Heater,...
Thermostat is installed but my baseboard heater doesnt stop heating
Simple wiring mistake or a faulty thermostat. Check your wiring against another stat if you have one.
Oct 26, 2009 | Off The Wall Heating & Cooling
I want to install 240v baseboard htrs in a below ground basement.
you must really love your hydro co
those heaters are a huge draw on your bill
why not install radiant heat they are cheep now in compairison
the unit is a central mount run the line in a loop arround basement and conect all the heaters in drop lines off the main line small thermostat valve for each room to control heat
cost is more for unit but savings are greater too they now make a light duty units designed for your porpose
single direct electric heaters are pigs on the hydro bell if you have gas or electric it is cheeper to run a small boiler or heat on demand system
Aug 04, 2009 | Heating & Cooling
Oil baseboard heat v electric baseboard heat.
Two 8 ft baseboards will heat this basement fine. You should eliminate any sources of flooding before you invest in refinished your basement.
Feb 14, 2009 | Fahrenheat PHH15002 Oil Filled Baseboard...
Replacing a non-programable thermostat for electric baseboard heater with model CT410B. This is a 4 wire thermostat replacement for a previous 2 wire. Directions indicate that I can do this. I connect...
If you take thermostrat back off and connect the wires together will baseboard heater get hot. If not you may have bad heater. If it gets hot your new tstat may be bad. The way you have it wired is correct. Most line voltage tstats have a ground screw. Your 's may not but will work without one .
Jan 23, 2009 | Heating & Cooling
Dimplex baseboard heater wiring
no does not matter but you must have a ground leg
Jan 05, 2009 | Fahrenheat Electric Convector Baseboard...
Wiring for baseboard heater
I hope you are using a Line Voltage Thermostat!! First, make sure that the power feeding the thermostat is coming from a two pole breaker of the correct amperage (20 amp). If you are using 12-2 wire with ground then please mark the white wire with black tape at each end to identify it as a HOT power source and not a Neutral wire (which is a grounded lead). Do the same for the 12-2 wires feeding the baseboard heater from the Line Voltage Thermostat. The wires from the thermostat (One Black & one White w/black tape) will be wired to each one of the two wires (one Black & one Red or two Black wires) at the baseboard heater. It doesn't matter which wire from the thermostat is wired to which wire at the heater, just as long as there is one wire to one and one wire to the other.(eg. Black from stat to Black at heater/White w/blk. tape from stat to Red at heater OR Black from stat to Black at heater/White w/blk. tape from stat to OTHER Black at heater). I have seen baseboard heaters with two black wires or one black and one red wire. Hope this helps, but if you are confused then please have an experienced tech. do it for you.
Dec 14, 2008 | Fahrenheat Electric Convector Baseboard...
Heating & Cooling Logo
184 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
