Question about Whirlpool Duet GHW9150P Front Load Washer
F 25 Code
Just got a new Duet, I haven't been able to wash yet because I get F25 code. I've tried unplugging and starting again, but no luck yet. It even stops on the spin and drain cycle. No one seems to be able to help.
  • 290 Answers
F25 is a motor tachometer code. In simple terms, the machine control does not know how fast the motor is turning so it shuts down. The problem could be in the motor, motor controller, the main control, or a wiring harness problem. Since it is new, I expect it is something simple like a connector that is not plugged in properly. I am seeing a lot of this kind of problem lately. They are getting in too big of a hurry at the factories I think.
If you can't wait for service, unplug the machine and remove the lower front cover and check the connections at the motor and motor controller. You can remove the top and check the connections at the main control. Just be sure not to change anything, just make sure all the plugs are pushed in to the connectors properly.
Let me know what you find out.
Mike
Posted on Jan 07, 2008
Whirlpool Duet Washer error f25
have whirlpool duet washer showing f25 code checked all connectionshave bare wires showing on rpm sensor on end of motor separated them and still showing code what else can i do
Oct 28, 2017 | Whirlpool Washing Machines
F 25 code
The pressure switch error code. Unscrewing 3 screw from the back, get the top cover off, you will see the small red part with a hose down to the drum. This is the pressure switch. Disconnecting the hose and blow into it to make sure it is not restricted. Unplug & re-plug the control cable and try to turn it on again. If the F25 still remains, replace the switch. To avoid this fault happen, using liquid soap instead of detergent.
Oct 13, 2013 | Whirlpool duet Washing Machines
Code F25 on Whirlpool Duet Washer?
First unplug your machine, then remove the front panel. There are 4 screws on the bottom front of the panel. Check the connection of the wire harness that connects to the motor make sure it is pushed in till it clicks. It could just be a loose connection.
Jul 29, 2011 | Whirlpool Washing Machines
I have a F25 code pop up and it will not spin
If this is the washer and not the dryer then error code:
F25 = DRIVE MOTOR TACHOMETER ERROR
This is a major error you can try some of the items listed below?
If the control is unable to properly detect motor speed, the machine
shuts down. If a failure occurs during high-speed spin, the door unlocks
after 3 minutes.
1. Verify the shipping system including shipping bolts, spacers and
cables are removed.
2. Unplug washer or disconnect power.
3. Check wire harness connections between the drive motor and the Motor
Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.
6. Check the drive motor for powered rotations.
Nov 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
What does F 25 code mean?
F25 means: Drive Motor Tachometer Error: If the control is unable to detect motor speed, the machine shuts down. If a failure occurs after high speed spin, the door will unlock after 3 minutes.
Possible solutions:
1) If this is a brand new unit insure that all shipping bolts, spacers and cables have been removed.
2) Unplug unit for 30 seconds.
3) Reconnect power
If this fails to solve the problem then you most likely have a connector problem between the MCU (Motor Control Unit) and the CCU (Central Control Unit) or a failure of one of these 2 units.
Oct 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F-25 KEEPS SHOWING UP AND DOESN'T START THE WATER FLOW
F25 is a motor tachometer code. In simple terms, the machine control does not know how fast the motor is turning so it shuts down. The problem could be in the motor, motor controller, the main control, or a wiring harness problem. Since it is new, I expect it is something simple like a connector that is not plugged in properly. I am seeing a lot of this kind of problem lately. They are getting in too big of a hurry at the factories, I think.
vickygmar
Aug 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Fault code F25
If you remove three screws along the bottom front the bottom panel comes off.
On the inside, on the right wall, is a plastic bag with a paper labeled "FOR SERVICE TECHNICIAN ONLY".
This has a section titled "FAILURE/ERROR DISPLAY CODES" with all the error codes along with an explanation and recommended procedure. For F25, this is:
If the control is unable to properly detect motor speed, the machine shuts down.
If a failure occurs during high-speed spin, the door unlocks after 3 Minutes.
Possible Causes/Procedure
1. Verify the shipping system including shipping bolts, spacers and the power cord are removed.
3. Check drive motor tachometer resistance. It should be approx. 115 ohms.
4. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
5. Plug in washer or reconnect power.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
I got this working for many on this site :)
Thanks
Fame !
Apr 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F25 error code
Hello twelsh2
Welcome,
You said, you started my washer and after a few minutes I'm getting this F25 code. Water starts to go in but it never starts washing. Any thoughts?
This is what F25 is telling you.
Condition
If the control is unable to properly detect motor speed, the machine shuts down. If a failure occurs during high-speed spin, the door unlocks after 3 minutes.
Check and Repair
1. Verify the shipping system including shipping bolts, spacers and cables are removed.
2. Unplug washer or disconnect power for 5 minutes (Rests the system)
3. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
If you can not find the fault , Please call service.
We have service sponsors available in your area here in our web site if you need one!
Let me know what you find!
Huuum
Please remember to leave a rating!
Sep 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F25 error code
this is scary. I got a brand new whirlpool duet sport I ordered from Costco.com. After 19 days of waiting for delivery it finally arrived and was installed by the whirlpool dlvy people. I read the instructions and started my 1st load within an hour of being installed. It never worked. Ok it work 6 mins and stopped on every cycle I put it on and then I got the error code 25. I called their customer svc number and they could not even tell me via the phone what that meant. I am suppose to have another delivered here HOPEFULLY next week but after seeing others having repeated problems I do not know if I should just say no take it all back.
Jan 27, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Duet GHW9150P Front Load Washer Logo
384 people viewed this question
Dan Webster
Dan Webster
Sal De
