Question about Linksys Wireless-N WRT150N Router
Linksys WRT150N Router: Linksys WRT150N Wireless Adapter: Linksys WMP300N Problem: Wireless network is not being established. It does not appear on the list of wireless networks in either the Linksys or the Windows manager. Wired LAN working fine. Antennas are firm in place. Tried with and without security. Wireless light on router in on. Doesn't work with my sister's D-Link DWL-G122 Accessed the router through router IP address, looked under wireless settings, and it's enabled and everything looks normal. Currently running on my uncle's D-Link 614+ router and everything works A1. Highly doubt that anything is interfering with the signal... Any ideas?
    Novelist:
    Scholar:
  • 136 Answers
I only have 3 suggestions.
1st one is to make sure the ssid is not similar to other routers you are using on your profile. ie.(change it to a unique name)
2nd is to make sure you check the box that says broadcast your ssid.
3rd check to make sure you select the router as an access point and not adhoc or infrastructure option. Finally you can try to change the channels eg. i like channel 3 b/c it doesnt interfere with any phone lines.
good luck
smeags.
Posted on Jan 07, 2008
I am trying to set up security on my Linksys router WRT150N?
Below are some pointers to secure your linksys router:
- Change the default password of the router. By default it is admin. Changing the default password will prevent unwanted users from accessing the setup page of your router. Click here for the steps.
- Change the default SSID or network name. This will allow you to identify your wireless network. Click here for the steps.
- Disable SSID broadcast. This will prevent other users from detecting your wireless network. Click here for the steps. Take note: You will need to manually enter the SSID on your wireless adapter to connect.
- Enabling wireless security on your router. This will require a security key before you can connect to the wireless network. Click here for the steps.
For additional security to your wireless networks, you may refer to this link.
Hope this helps! Happy Holidays!
Dec 28, 2009 | Linksys Wireless-N WRT150N Router
Where do I find the network key for my linksyswrt150N?
This is located under the wireless settings on your linksys. This is something you would have set up when installing the router. If you don't remember or it is confusing.. Change it. I usually use the KTIP security because you can use a normal passphrase that is easy to remember. Hope this helps
Sep 12, 2009 | Linksys Wireless-N WRT150N Router
Encryptiing
Is your router from linksys also? How many wireless computers do you have? Note that if you encrypt your router, you need to make sure that each wireless computer gets the exact encryption keys you will use on the router. Usually the linksys router page can be accessed via http://192.168.1.1. Leave username blank, password is "admin". Go to Wireless >> Wireless Security. Select WEP-128 key. Enter in a passphrase and hit generate. Copy key #1 on a piece of paper (make sure it's 26 characters) and click apply. Next, go to each wireless computer and use encryption key#1 when you connect to the linksys router.
Jun 19, 2009 | Linksys WMP300N Pre-802.11n Wireless...
Cannot connect to wireless network
may be your router needs a firmware upgrade.
check the router's website.
and make sure the router and the wireless card are both using the same 802.11 protocol
Feb 22, 2009 | Linksys WMP300N Pre-802.11n Wireless...
Router problem
This is a problem with the router's firmware, so i suggest you go to linksys web site and download the latest firmware for this router and upgrade it , so everything will be working but if still the same problem after the update better call linksys support and have the router replace...
Feb 19, 2009 | Linksys WRT150N Wireless N Router -...
My internet icutting out unless i plug power adapter from router
I installed the software for the router but i can't use my laptop wireless
your Wifi is not Enable Yet,
you have to login into your Linksys and go to Wi-fi and Enable your Mac address for your Router..
Feb 02, 2009 | Linksys WMP300N Pre-802.11n Wireless...
Linksys Wireless-N pci adapter model wmp300n
If it says local or unidentified network that means you are just connected to the router on the network but not through the internet. Try to go to manage wireless network, remover your network there and add it again, connect to your own network and make sure to type the correct network key., then check again. You can also try connecting to other wireless network to further isolate the problem.
May 25, 2008 | Linksys WMP300N Pre-802.11n Wireless...
WMP300N
http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&pagename=Linksys%2FCommon%2FVisitorWrapper&cid=1144763512962
this page above mentione resolved your problem.
Download the driver.
Thanks
Sergio
Mar 01, 2008 | Linksys WMP300N Pre-802.11n Wireless...
Linksys Wireless-N WRT150N Router Logo
226 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
