XBOX 360 to JVC RX 5060b
I am trying to run my xbox 360 standard red yellow white inputs through my new JVC receiver. When I connect my xbox to the dvd input on the back of my reciever the sound comes through just fine on the dvd channel of the reciever but I am confused how to receive the video input from my xbox 360. Presently my comcast cable box connects straight to my tv and bypasses the amp and my audio from my television then goes back to the amp. Any ideas on how to run my video signal from my xbox through my receiver?
  • 1 more comment
  • dogpoundgang May 22, 2008
    i have the same problem sound but no picture
  • shah23 Jan 07, 2009
    I have similar problem, component green/blue/red and audio white/red going to my yamaha reciever rx-v1800 from xbox 360.  I get sound, but no video when I change input to the connection I have it set to.  I have hdmi output going to tv.  If i play from dvd player and select dvd input, dvd movies work just fine.
    Any assistance would be great.
  • Anonymous Mar 22, 2014
    Iv got a lowry television and cant find the audio receiver code to connect to my xbox one Can you help with this
I had the same problem. You should check to make sure that the switch on the XBox cable is set to HDTV and that you change the resolution on the XBox to 720P/1080i.
Posted on Mar 07, 2009
    Genius:
  • 1,067 Answers
Does your reciver have video ins and outs monitor out u have to send master video out from jvc to tv 1st u know im open for chat
Posted on Jan 07, 2008
What's your problem?Im trying to hook up my xbox 360 to my JVC 27 inch TV, I installed the yellow to video input and the red and white to audio input and all get is the audio and no video. What am I...
Troubleshoot.
1. Ensure yellow is actually connected to an "input" slot.
2. Ensure TV is set to the correct input source.
3. Ensure your yellow, white and red RCA connectors are grouped in a single input source to TV. Sometimes the "component" and "composite" inputs are grouped closely together.
4. Consult the TV manual for hookup instructions.
5. Conduct a continuity test on the yellow xbox wire with a multi-meter.
Oct 04, 2011 | Sega The Club - Xbox360 for XBox 360
XBOX 360
How to Connect XBOX 360
This is the back of the Xbox 360. The ports for the power cable, A/V cable, and ethernet cable are pretty easy to find. When you set up your Xbox 360, make sure it is in a well ventilated area that is free of dust. Dust and overheating are the two main causes of problems in electronics so choosing the right placement for your Xbox 360 is important.
This is the standard Xbox 360 A/V cable that comes with the premium version of the Xbox 360. The wide silver end connects to your Xbox 360 while the other end connects to your TV. The Yellow (video) cable is for standard, non-HDTV sets. You will also use the Red+White audio cables for a standard set. If you have a newer TV or an HDTV set, you can use the Red+Green+Blue video connections along with the Red+White audio connections.
This shot shows what the back of most TVs look like. If you have a standard TV, you'll only have the Yellow+Red+White connections. If you have a newer TV or HDTV, you should have the same connections that are shown in the pic. This step isn't too hard since the cables from the Xbox 360 and ports on the back of your TV are all color-coded.
If, and only if, you have an HDTV and want to use your Xbox 360 in 480p, 720p, or 1080i resolutions you have to slide a little switch over on your A/V cable. On the end of the A/V cable that connects to the Xbox 360, there is a little switch that you'll need to click over. If you do not have an HDTV, you can skip this step.
Now that you have the audio/video cables connected, the next step is to hook up the power supply. Connect the two parts as shown in the picture and then connect the "power brick" end to your Xbox 360 and the other end to a wall outlet. The big power brick needs plenty of ventilation just like the main system so try to have an open space on a shelf for it. It is not recommended that you set it on the carpet.
Once you have everything hooked up, you are ready to go. Press the large circular power button to get things started. If you have a wired controller, plug it into a USB port behind the little USB door. If you have a wireless controller, hold the silver "X" button in the middle of the controller until the upper left quadrant of the system power button as well as the ring around the "X" button on the controller light up. If it doesn't light up, press the controller connect button on the Xbox 360 as well as the connect button on the top of the controller.
If this is the first time the system has been used, you'll have to go through an onscreen setup process. This is simply setting up your player profile, choosing HDTV settings if available, and/or signing up for Xbox Live service. The system walks you through everything.
Now you are ready to play.
Sep 06, 2008 | Microsoft Xbox 360 Console
I have just bought an xbox 360 conected it to my tv allcables connected picture great but no sound
Hi Douglas
I imagine you have bought the new slim Xbox 360? Did you use a HDMI cable to connect it to your TV or did you use the standard cable? If you used a standard AV cable ensure that you connected the red and white cables into the same AV input as the yellow video cable.
Mar 05, 2011 | Microsoft Xbox 360 Console
How do I connect a Xbox 360 Console without HDMI to a Grundig LED-tv 40" to get the best picture?
If your tv has a composite wiring inputs (5 wire red,white,yellow,blue,green) use them it will provide a better picture picture quality than the standard rca a/v cable (red,white,yellow) After you connect the composite cable from console to tv go into system/console settings/tv picture quality and adjust settings there
Jan 12, 2011 | Video Game Consoles & Games
My cable from my xbox 360 ,will not connect to my tv as i have only red /yellow/white,connections on my tv ,i am trying to get hdmi,i have tried a hdmi cable from xbox to tv ,what else can i try.thanks.
You are going to need to get another cable. Your TV was not made for HDMI input. The best display you can get is standard definition. It would be cheaper and easier to get a new cable vs. getting an HDMI to Component adaptor. Radio Shack sells these cables pretty cheap. Good Luck!
Respectfully,
Don
Oct 27, 2010 | Microsoft Xbox 360 Console
I have a jvc i'art tv. model # av-27f476. i have an xbox 360. how do i hook em up? i have plugged the red, white, yellow cables to the corresponding colored jacks on the front of my tv. i turn my xbox 360...
on the xbox i think the hd works with all 6 cables connected so you will need to switch it back to standard definition. if its still not working try it via scart m8
Mar 06, 2010 | Video Game Consoles & Games
How do i connect my xbox 360 to my yamaha rx-v665 receiver
If you are gonna connect the x-box to the yamaha directly you would have to connect the red and white cables to one of the inputs on the reciever and the yellow to the video on your tv.
Feb 16, 2010 | Yamaha RXV665BL Receiver
Pyramat 450 wireless sound rocker. Comes with white/yellow/red rca jacks, how would I install that to a xbox 360? The xbox will play through chair if I connect xbox input jacks to chair! But you then get...
You need to go buy another cable, get a good length red and white rca cable one that suits the distance between the chair and the xbox.
Then you need to get a female to female rca adapter. Connect the adapter to the ends of the red and white audio cables on xbox, connect your new rca cable to the adapters, connect the cable to your pyramat seat. Connect xbox tv cable to tv as normal.
Jul 11, 2009 | Pyramat PM450WR for PlayStation 2,...
Xbox 360 hookup problem
Check the video cable coming out of the xbox, depending on which model xbox it is (arcade, pro, elite etc.) it will most likely have both component cables - green, blue and red or RCA cables - Yellow, red and white. It sounds as if your JVC would only be able to run RCA cables (due to its age) so use the yellow cable for video and white and red (or just white if you only have a yellow and white input) and then make sure the switch located on the cable is switched to "standard" and not "hi definition" hope it helps. aus_joel@hotmail.com -if you have any further problems
Jul 06, 2009 | JVC LT-47X788 47 in. LCD HDTV
Hooking up Xbox 360 to JVC TV 20 inch 1 year old tv from Luxembourg
change the plug on the back of your xbox 360 from hd to tv unless of course your tv is hd then change it to hd :]
Jan 27, 2008 | JVC TV-20241 20 in. TV/VCR Combo
546 people viewed this question
 Grubhead
Grubhead
