Is the light on the power supply? if so is it red, green or amber? this can help. If its red it could be either
the power supply which is faulty or a major problem with the 360 which is causing a short or something
similar. What is probably wrong witht he 360 is the 3rrod:
When the Xbox 360 overheats it causes the lead free solder to crack, the more that crack the worse the
machine will get. So eventually I suspect your machine will die completely and show either 3rrod or e74.
To remedy this you need to strip the console down and replace what's called the X-Clamps, at the same
time replace the heat-sink paste and then you need to re-heat the whole board. We use a special IR over
which re-bakes everything and re-seats the solder properly, a lot of people use a heat-gun but you have
to be very careful.
when puting new games, the game won't load only reads play dvd and then shows a huge xbox 360 logo....
(More)
when puting new games, the game won't load only reads play dvd and then shows a huge xbox 360 logo. I can play older titles.
what can i do to fix my xbox 360 with 2 red ring. i already took apart and cleaned an the fans are...
(More)
what can i do to fix my xbox 360 with 2 red ring. i already took apart and cleaned an the fans are working.
my xbox is having the invalid format problem...happened while playing, the colors went weird so i...
(More)
my xbox is having the invalid format problem...happened while playing, the colors went weird so i turned it off. when i turned it back on it says invalid format but there is still audio, it sets up normally to the dashboard (i know this by the audio) and the power light is green as normal. after playing around with it a bit it no longer says invalid format but instead now says no signal at all. the rest still working normally. any ideas for advice or solutions?
