The print head is clogged.Try unclogging with cleaning tests in maintenance mode.If not help you can try unclogging manually.Warning!!!This can lead to damage of print head.Try it in last case.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.Call Canon for support.
Was this helpful?
Yes
No
Popular Solutions for Canon PIXMA? MP600 All-In-One
the type of print head is incorrect comes up on my printer. Original print head is on printer. How...
(More)
the type of print head is incorrect comes up on my printer. Original print head is on printer. How can I fix this
My printer MP600 present three discontinuous line in mine of letter at every copy page. what...
(More)
My printer MP600 present three discontinuous line in mine of letter at every copy page. what is the problem.
When I turn on the computer the system does not startup due to a problem with the usb printer cable...
(More)
When I turn on the computer the system does not startup due to a problem with the usb printer cable connected to the computer. What should I do?
