Question about One For All URC-3021 Remote Control
Battery died and need to set up codes for Fisher TV
The batteries in remote died. when I put new batteries in the remote would not interact with the tv. It did before the batteries died. LED lights up when follow the basic instructions but don't have code to enter to complete setup.
    Novelist:
  • 129 Answers
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC3021
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(For replacement remotes visit www.sparky-uk.com)
Posted on Jan 07, 2008
6ya staff
SOURCE:
TV remote won't work after changing batteries
When battery is changed, all the previous settings will be lost from the remote control. You should once again set it to your device, using codes.
Jan 10, 2013 | DISH Network Televison & Video
I have a UMC TV /DVD Combi the remote control i got with it no longer turns the TV on or off, so i bought a universal remote and it cant seem to find the code for the remote so i was wondering would anyone...
First of all, did you put new batteries in the remote control?
That usually solves the problem, because when the batteries get weak
the output infrared signal also gets weak.
With a new universal remote control, there is a booklet containing the
codes to use for many different TV receivers. If your specific TV model
is not listed, try using one that appears to be similar to it. If that does
not work, try turning your TV on with the new universal remote. If you
can turn it on, then you may be able to have the universal remote
program itself by interacting with your TV. Turn it on and hold the
remote so that it points to the TV set and hold it there for about 30
seconds. Then try turning the TV off and on again and try to use
the channel change feature. Try this a few times to give the TV and
the remote a chance to talk to each other. Keep the remote pointed
toward the TV.
Aug 29, 2011 | Televison & Video
We've lost our manual for the TV. The remote control has died and we are unable to set the universal remote control without the code. It is a Sharp LC-325B24U.
I am a old tech and have done this many times. take the old remote apart and use a tooth brush and Clean all of it with dish washing liquid and water.
just enough soap to sud. and then clean with alcohol strait vodka if you don't have denatured.
then put over a air vent for 24 to 48 hrs. put new battery's in it and you should be back up and running
it must be totally Dry before you put battery's in it.
Dec 25, 2010 | Televison & Video
My phillips universal remote needed new batteries, so i put new ones in, but now it won't work. can you help me?
When the batteries died the remote forgot all the stored codes. All you have to do is to input them again.
Jun 19, 2010 | Televison & Video
Sanyo TV with no remote but have a fisher remote, how can I set u
you can try this,
sanyo tv codes 025,023,054.
fisher tv 025.
Apr 09, 2009 | Televison & Video
Connection for hd.
That depends on what your HD source is: cable, antenna, satellite,DVD....please be specific about what you're trying to hook up to your TV.
Remotes don't "die" because the battery died. If you've put in new batteries and it doesn't control your Olevia TV, then the remote is likely broken. Again, be SPECIFIC. What remote are you talking about? The original Olevia remote? A universal remote?
Curmudgeon
Dec 17, 2008 | Olevia LT37HVS 37 in. LCD HDTV
My girlfriend took the batteries out of the Phillips universal remote. When she replaced them with new ones, the remote would not respond to the Toshiba TheaterView big screen television it was programmed...
first push code buttom then press tv then start pushing power buttom until tv go off (do not push power again after tv go off if this happen need to do everything again)then press enter and try again
Jul 27, 2008 | Televison & Video
Remote wont work
for some reason unknown, the laser or infrared diode has died
May 20, 2007 | RCA 257003 Remote Control
One For All URC-3021 Remote Control Logo
Top One For All Televison & Video Experts
Joe Negus
Joe Negus
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
