Question about Acer Aspire T310 PC Desktop
Acer descktop t-180 stuck on "verifying DMI pool DATA"
Stuck on "verifying DMI pool DATA" on start up and won't go further
  • 2 more comments
  • Anonymous Aug 07, 2008
    I have also Acer Desktop Pc and comeup on the same problem verifying DMI pool data........
  • dbix Sep 06, 2008
    acer Aspire desktop t-180 ED380M
    I have done all the following and combinations of them that I can imagine:
    Reset the default settings (many times)
    Removed the battery
    Disconnected DVD drive
    Connected another DVD drive that worked in another computer
    Disconnected hard drive
    Connected another bootable hard drive
    Changed boot order
    Used a boot disk in the hard drive.
    Unplugged all Ram but 1 GB stick
    Tried another 1 GM stick
    unplugged and replugged in hard drive cables
    In the bios, the computer recognizes the DVD and hard drives, but it never gets to them.
    It was working at one point about a week ago. All seemed fine then except it did not recognize the DVD drive even if I uninstalled/installed the proper driver.
  • mstoddard Feb 09, 2009
    I have the sam issue on Acer Veriton M410. Have tried everything you did, still no luck. What caused this?
  • Anonymous Mar 22, 2014
    windows doesn't start
    Genius:
  • 1,226 Answers
Remove and clean the memory with soft material and then fixed it back and then start the system.
If not solve then;
Remove the Hard drive and fixed back then boot the system,
If not solve then;
When booting press "F2 or Delete" to enter the bios setup.
In there find the "Load BIOS Default setting" and select and then enter.
Press "F10" to save and exit setting.
If not solve then;
REmove and replace the CMOS Battery and then do this Again
""When booting press "F2 or Delete" to enter the bios setup.
Press "F10" to save and exit setting."
If same problems Occur;
Try examine the motherboard maybe some portion on it overheat. in this case"Mother board damage" However if found nothing on the board "
do not hesitate to notify me for further instruction.
Posted on Jan 07, 2008
When i boot the computer it says verifing dmi pool
Hello there and welcome to fixya
A. DMI or DesktopManagement Interface (pdf) is a layer of abstraction between system components and the software that manages them. The System Management BIOS (SMBIOS) is an extension of the Basic Input Output System (BIOS) that formulates and delivers this information to the operating system. The pool data is the information. In short, when the BIOS is "Verifying DMI pool data" it is verifying the table of data it sends to the operating system (Windows, etc.). If it isn't sucessful, it should return an error. Wait a reasonable period of time for it to finish. It may make take some time or it may be stuck. Possible fixes:
1. If you changed the hardware just before this problem occurred (e.g., installed a new hard disk drive), unchange it.
2. If you installed a new hard disk drive, set the motherboard CMOS Setup to Auto for the drive type. You may have to disconnect the drive first.
3. Enable "Reset Configuration Data" (may be "Force Update ESCD" in some CMOS Setuups) in the motherboard CMOS Setup PNP/PCI configuration. (Rebooting will automatically disabled it after it has done its thing.)
Oct 15, 2011 | E-Machines eMachines Desktop PC
Stuck at verifying dmi pool data
Try restarting in Safe Mode, press F8 at bootup and then either troubleshoot or do a system restore.
Feb 02, 2010 | Acer Aspire M1100-B1300A Refurbished AMD...
DMI Pool Data, Acer
You need a higher computer specification for Windows 7.
Acer Aspire T310 is design only for Windows XP Home/Professional and Windows 2000 according to Acer Support Page:
http://support.acer.com/acerpanam/desktop/0000/Acer/AspireT310/AspireT310sp2.shtml
Jan 20, 2010 | Acer Aspire T310 PC Desktop
Wont start up grey screen with warning verifying dmi pool data on my desktop pc which is acer aspire
well varifying DMI pool data is not a warning its a process where your system hangs. install new windows or repair the old one.
Jan 07, 2010 | Acer Aspire E380 ASE380-UD500A PC Desktop
This Acer AST 160 I'm working on crashed...
Computer stops at verifying dmi pool data. Issue: Computer stops at verifying dmi pool data.
Cause: This issue can be caused by any of the below reasons.
  1. Corrupt boot files on the computer.
  2. Settings for hard disk drive are not correct.
  3. Floppy diskette or CD in computer causing issue.
  4. Boot devices not set properly.
  5. BIOS corrupt or misc. setting not set properly.
  6. Connections loose or disconnected.
  7. Bad Hard disk drive or other bad hardware.
Solution: Corrupt boot files on the computer
If the computer has no bootable files on the drive it is attempting to boot from it is possible that the computer may halt at " verifying dmi pool data..."
To resolve this issue:
  • Boot from a bootable floppy diskette. Ensure that this diskette was made on the same Microsoft Windows operating system that is installed on your computer.
  • Once at the A:> prompt type "sys c:" and press enter. This should report the message "File system transferred." Once transferred remove the diskette and reboot the computer.
If the computer continues to not boot attempt to re-create the master boot record by booting from the bootable floppy diskette again. Once at the A:> prompt type "fdisk /mbr" and press enter. This should return you to the prompt without giving you any message. Once at the prompt remove the diskette and reboot the computer.
Additional information about the "fdisk /mbr" command can be found on document CH000175.
Note: The above information only applies to Microsoft Windows users. If you are running a Linux / Unix variant or other operating system such as OS/2 and the computer is freezing at this DMI message ensure that Linux / Unix has been properly installed first and/or your boot manger is not corrupt.
The computer freezing at "Verifying dmi pool data..." may be caused when the hard disk drive settings within CMOS are not set properly. Enter CMOS and verify that the hard disk drive settings are set properly and/or that it is set to Auto Detect. Additional information about entering CMOS setup is found on document CH000192.
Verify no floppy diskette or CD is in the computer. In some cases the computer may be trying to boot from either of these drives causing issues with the boot sequence.
The computer stopping at " verifying dmi pool data..." can be caused when the boot devices on your computer are not set properly in CMOS. First, verify that no CD or diskette is in your computer. If a CD or diskette is in the computer attempt to remove this first to determine if it was attempting to boot from it.
If No CD or diskette is in the computer and your computer still halts at the DMI message enter CMOS setup (steps found on document CH000192) and verify that the boot options are set properly. We commonly recommend that the floppy be set the first boot device, hard drive as the second boot device and the CD-ROM as the third boot device.
If none of the above recommendations have resolved your issue
Sep 10, 2009 | Acer Aspire T160 (AST160UA3400) PC Desktop
Acer desktop stuck on "Verifying DMI Pool Data...."
thats a os systems failer it will need to set back to new but back up your data first as this will be lost
Aug 03, 2009 | Acer Aspire T310 PC Desktop
Acer desktop T180 is stuck on verifying DMI pool DATA..
verifying DMI( Data Migration Information/or Dynamic Migration Information) pool data refers to hard disk function. check the hard drive to see if it functioning properly.
Jul 12, 2009 | Acer Aspire T310 PC Desktop
Computer says something about verifying pool data
If it says something along the lines of verifying dmi pool data then you might have a problem with your BIOS ( the setup utility you refer to ). Here is a URL that describes a solution to this problem, it is pretty intense if you don't have at least above average computer skills - http://www.duxcw.com/faq/computer/dmi.html. Let me know if you need any further assistance with this.
Serge C.
Mar 30, 2009 | Acer Aspire T180 PC Desktop
Cant boot pc
hi i have put together a pc but when i power it up it say soft menue has changed and then says verifying dmi pool data pls can anyone help thanks
Sep 04, 2008 | Intel Motherboard
Acer Aspire T310 PC Desktop Logo
2,900 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
