Question about Coby MP-C7085 MP3 Player
Problems with my coby mpc7085
It wont turn on when i plug it in the usb port
Coby fuckin Sucks
Posted on Jan 30, 2008
Coby mp3 batterys wont charge modle mpc7085
Hello
Probably the battery is faulty or has stopped working. Or the connection from usb to the battery is not working. If that the cause you need to take it to a tech shop for repair. I would suggest (if you are good in repairing tech electronic) check the USB port first if that's damaged then you need to replace that or in other case if the battery is faulty you will need to replace that.
Hope this helped
Apr 13, 2014 | Video Cameras
My coby kyros wont charge
Try plugging in your charger to a different outlet. If that doesn't do anything, there might be a problem with your charger or your USB port on the Tablet. May have to replace the charger.
Mar 07, 2011 | Coby Kyros 716829701508 Tablet PC
I used my coby mp3 for the first time and now its kaput, doesnt charge and wont turn on.
Did you accidentally eject it, without safely removing it from the task bar?
If so, try inserting into either front usb ports or the usb ports in the back!!! Best of luck to you my friend!!
Jan 16, 2011 | Coby Audio Players & Recorders
My coby mp610-2g wont charge i plug in my usb cable it wont do any thing please help me
Try to change the usb cable. If still can't, that means your mp3 player usb port is damaged. You will need to get it fix.
Apr 27, 2010 | Coby MP-610 MP3 Player
How do I recharge Coby MP3 player? I plugged into USB port for over an hour but it stopped playing after about 20 minutes. Do I need to replace the battery or charge it longer or both? Thanks. Claudia
Coby MPC7085 requires a 12 hours charge when used for the first time.
Always use a direct connection to the computer when charging with the USB cable: a hub or cardreader should be self-powered.
See page 12 of the manual:
http://www.cobyusa.com/files/manuals/MPC7085_MN.pdf
Sep 28, 2009 | Coby MP-C7085 MP3 Player
Windows not Recognizing COBY MP705-8G
Make sure you have plugged your Coby MP3 player into a USB 2.0 port. The Coby does not support the USB 1.0 standard. If you are getting an error that "This device can perform faster..." your port is an older USB type. I have both types on my computer and the Coby would not install until I plugged it into my 2.0 port.
Hope this helps.
Jun 26, 2009 | Coby MP-705 Digital Media Player
How do I charge my Coby Mp3 player MPC885?
Takes about 3 to 4 hours to fully charge if you have a USB 2.0 port.
Feb 03, 2009 | Coby MPC895 MP3 Player
Getting a e-book on a coby mpc7085
Ebook files are just play .TXT files. So basicall you type something out in regular notebook on your computer, save it as a .txt file. Once it is save on your computer:
1. Turn on Mp3 player, go to settings, make sure USB mode is set to MSC or USB DISK
2. Connect MP3 player to the computer
3. Go to 'Start' button, go to 'My Computer'
4. There should be a drive labeled removable disk, double click this drive.
5. inside this drive there should be a folder labeled EBOOK, drag your .TXT files to this location.
6. Disconnect MP3 player, go to Ebook menu and you should be able to read the book or TXT file.
Apr 26, 2008 | Coby CBY705 MP3 Player
Mpc7085 is fozen
well im only a 12 year old really smart so what u can do is in back on it it says reset press on it and it will unfreeze
Jan 13, 2008 | Coby MP-C7085 MP3 Player
Mp3 wont work
Just format it and reinstall the firmware.
Jun 16, 2006 | Coby MP-C541 (128 MB) MP3 Player
Coby MP-C7085 MP3 Player Logo
88 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
