Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washing machine the washing machine reaches to emptying the water then stops and nothing happens.
    Sergeant:
  • 271 Answers
You may have some thing iin the filter or your pump is gone
Posted on Jan 06, 2008
Hi, I have a Candy Grand comfort which has just stopped working. the power is there lights on but when I turn the dial it clicks as if to start but nothing happens. Thanks in advance.
Could be the door interlock or simply there is no water entering the machine. Check water supply and also the vales inside the machine . the solenoids should buzz nd hum a little if they are energised but could still be blocked ???
Dec 18, 2016 | Candy Washing Machines
Machine does not seem to be filling properly, then does nothing else.
Sounds like you're fill valves are junk which sadly happens allot. This video is very generic but should give you an idea
Jul 06, 2017 | Hotpoint Ariston Aquarius WD420 Front Load...
My Roper washer will run through wash cycle then stops. Nothing will work for 40 minutes then I can put it on rinse then the cycle will complete. What could cause the stopping with nothing working then...
It could be that the machine is trying to heat the water in the drum, but is not able to for some reason. The timer is waiting for the water to reach temperature before advancing. Posssibly a broken heating element. This can happen even on a cold cycle as most machines prefer to heat all soaping water to about 30C regardless of the temperature setting.
Sep 13, 2013 | Roper Washing Machines
Washing machine does NOT stop filling w/ water!
If the m/c keeps filling, where is the water going ??? if the m/c doesnt reach the required water level it will not start, check the drain hose at the back, make sure its at least 24" above floor level, if it lower then it will just empty as quick as you fill it on gravity.
Nov 19, 2009 | GE Washing Machines
My frigidaire top loader fills with water at the beginning of the wash...then nothing. it just sits there full of water.
Hi, could be your timer motor, timer or water level switch, first push timer knob in and manually advance to wash or spin cycle (program) then pull knob, see if machine operates, let me know, then i can tell you exactly what's problem.also advance timer, to spin cycle (program) machine should pump out water, or you can lower drain hose into bucket and empty machine, you should empty machine and try again, let me know what happened, we can solved this together. good luck.
Aug 12, 2009 | Frigidaire FWS933F Top Load Washer
I have the same problem , the water filled then stopped working ,
sounds like your timer burnt out or is sticking somtimes giving the top of the controll box a firm smack will get it freed up
Jun 28, 2009 | Maytag Performa PAV2200
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
15 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
