HI I HAVE A TOSHIBA SATALLITE A55 SERIES. INTEL(R) CELERON(R) M PROCESSOR 1.50GHZ. I WOULD LIKE TO KNOW HOW MUCH MEMORY CAN I MAX IT TO, AND WICH MEMORY SHOULD I USE. PC2700 OR PC25300 OR DDR333
You can only max at 1GB. You should use the PC2700 DDR33 512MB memory to upgrade the system. Should cost you less than $25 for 2 of the standard power SODIMMs or $50 for 2 of the lower power SODIMMs.
Was this helpful?
Yes
No
Popular Solutions for CMB Software T43 750 512/60 14
I bought new laptop. windows 7. I installed webroot 6.0 and it isn't compatible.( oops!) Now when I...
(More)
I bought new laptop. windows 7. I installed webroot 6.0 and it isn't compatible.( oops!) Now when I boot up, windows tries to start but does not get to desk top. what do i do?
I was trying to create recovery cd's using the AI Recovery Burner, but it keeps saying there is no...
(More)
I was trying to create recovery cd's using the AI Recovery Burner, but it keeps saying there is no media detected? Is my new laptop defective?
i changed the grapics card setings to be able to play dvd but now the screen is black but the...
(More)
i changed the grapics card setings to be able to play dvd but now the screen is black but the windows xp shows up at start up then there is sound but no screen
Hi Everyone, Am facing a strange problem. I have a Dell Inspiron 1000, 2.2Ghz Celeron processor,...
(More)
Hi Everyone, Am facing a strange problem. I have a Dell Inspiron 1000, 2.2Ghz Celeron processor, 256MB RAM, 80GB HDD. In the BIOS setting there is a setting for Display, which is set to XGA 14.1". This setting automatically changes to 'Unknown' & the screen does not display anything when you 'ON' the laptop. The boot up screen too is not displayed. However the laptop boots fine into Windows XP ( this is observed when you connect an External monitor to the laptop's VGA port. I have also observed that if the value in the BIOS is 'XGA 14.1" ' then only the laptop recognises the display. I have tried changing the CMOS battery , but with no results. I also tried to set the BIOS settings to 'Factory default' settings, still of no use. If at all I managed to open the BIOS settings ( whenever the display is visible), the 'Display' setting keeps on fluctuating intermittently. Also, cannot change the values manually. Kindly help. Thanks for attention.
