xbox starts up right no red ring of death but theres not sound or picture. but when the 360 starts up with picture a few minutes its color of everything is different and not right
This is a common fault with the 360, it says that its a "general hardware failure" which could mean
anything
really. In truth its the lead free solder that cracks with so much heat and as a result the Xbox 360 fails
causing the 3rrod (3 red rings of death) or e74 or even no sound but graphics or sound and no graphics
just like you are reporting.
Firstly get a spare AV cable from someone else, try this, if that does the same then try a different
SCART
input on the TV. if all this fails you need to fix your machine as it WILL get worse
You will need to get a 3rrod repair kit or get someone to fix it for you, there are guides available on the
internet. I'm in the middle of producing one right now that I will make available free of charge for all fixya
members. To remedy this you need to strip the console down and replace what's called the X-Clamps, at the same
time replace the heat-sink paste and then you need to re-heat the whole board. We use a special IR over
which re-bakes everything and re-seats the solder properly, a lot of people use a heat-gun but you have
to be very careful
Linda
Whenever I turn it on, it has a red light on the bottom right of the console. The screen says E-74...
(More)
Whenever I turn it on, it has a red light on the bottom right of the console. The screen says E-74 Error. I was reading how to fix it, some suggested its the A/V Cable. I tried to blow any dust off, and its not the A/V cable. How can I fix it?
when puting new games, the game won't load only reads play dvd and then shows a huge xbox 360 logo....
(More)
when puting new games, the game won't load only reads play dvd and then shows a huge xbox 360 logo. I can play older titles.
what can i do to fix my xbox 360 with 2 red ring. i already took apart and cleaned an the fans are...
(More)
what can i do to fix my xbox 360 with 2 red ring. i already took apart and cleaned an the fans are working.
my xbox is having the invalid format problem...happened while playing, the colors went weird so i...
(More)
my xbox is having the invalid format problem...happened while playing, the colors went weird so i turned it off. when i turned it back on it says invalid format but there is still audio, it sets up normally to the dashboard (i know this by the audio) and the power light is green as normal. after playing around with it a bit it no longer says invalid format but instead now says no signal at all. the rest still working normally. any ideas for advice or solutions?
