Mitsubishi WD-62525 62 in. Rear Projection HDTV Television
Problem for Mitsubishi WD-62525 62 in. Rear Projection HDTV Television
I have a mitsubishi Medallion hd 1080 and the
By daveananda11 on Nov 10, 2009
I have a mitsubishi Medallion hd 1080 and the picture is bad, colors off plus there is a yellow section along the top o the screen. Can this be repaired
Solution #1
posted on Nov 10, 2009
Not Rated)
Chu3505
Rank: Guru  Televisions & Videos  Expert
Rating: 85%, 418 votes
Yes,U know how to solders?Ur convergence it dead,must replaced it with a convergence kit,use what in that kit.Tries these websites for the convergence kit.Tv repair World.com,Tv repair Kits.
Was this helpful?
Yes
No
Popular Solutions for Mitsubishi WD-62525 62 in.
Questions and Unsolved Problems for Mitsubishi WD-62525 62 in.
Do you recommend Mitsubishi WD-62525 62 in. Rear Projection HDTV Television?
Answer
Answer
TV doesn't respond to Remote. It ignores the commands given and then shuts down... then the Timer... (More)
Answer
mitsubishi tv diamond is broken. it just turned off for no reason and will not come back on. can you... (More)
Answer
when the tv is on every 15 to 45 seconds the TV blinks and it does it every time. i tried resetting... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Mitsubishi WD-62525 62 in....:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
