I have an old godman furnace GPM050-3 nedd to replace the circuit board, I allready got a new janitrol circuit board, but looks different, I need instructions on how to replace that
Look on the new board and the old boards to compare the markings where the wires a hooked at. For example "L1" on the old board would go to "L1" on the new board. All the wires on the old board sould have a counterpart on the new baord. Just switch them one by one so you don't get confused.
i have reset the boiler but the red light is still flashing, what does this mean? the message *low...
(More)
i have reset the boiler but the red light is still flashing, what does this mean? the message *low pressure or pump failure has appeared on the boiler lcd^ can somebody help? Thanks
I have the blower assembly apart. I have a liquid teflon sealer with a maximum temperature of 550...
(More)
I have the blower assembly apart. I have a liquid teflon sealer with a maximum temperature of 550 degrees fahrenheit. Will this be enough for the hot air from the combustion burn chamber air temperature, when it circulates through the blower assembly? The ribbon gaskets show leakage , and my best guess is, a suitable temperature sealant in addition to the ribbon gaskets would be fine. Also,I found a bearing without a wavy spring washer. What is the correct description of this part? I will need advice on testing the solenoid ,and, when reassemblying the combustion blower assembly,how to syncronize this. I read that this needed a device to accomplish this. What is the name of the suitable device to syncronize the ignition event in the burn chamber ,if I am understanding this correctly?
