Question about HP Officejet 5610 All-In-One InkJet Printer
Says paper jam but no paper
My printer says paper jam but there is no paper in it the last time it was used a little long plastic piece came out and now all it says is paper jam and the ink cart slam back n forth
    Problem Solver:
  • 9 Answers
Hmm you might need
a new printer cause that happened to my old
dell printer
clean it from the inside with a little air nozzle
that blows hard thats what i did it can be dust...
Posted on Jan 07, 2008
Paper jam
Sometimes you have to tear it out piece by piece. I have had to use tweezers to remove the last little bits. Also, a tiny bit of paper remaining can prevent the printer from printing again. Be careful not to damage the printer while getting the paper out.
Sep 08, 2012 | Canon imageCLASS MF6550 All-In-One Laser...
Xerox phaser 8560 says "paper jam - open front
try cleaning the microswitches. it may also have a sensor and if the little plastic piece that crosses between them has broken off it will throw codes. mine is ok so i cant say for sure but you can try to glue a suitable piece in there to trick the printer if thats the case or bypass the sensor. just a few suggestions from my experience with electronics
sensor is kind of this: gap is where the plastic part is supposed to go in between.
Oct 12, 2011 | Xerox Phaser 8560MFP Laser Printer
I removed the paper and it won't reset. I've looked all through it and there is no more paper in the printer. It will not do anything else but say that there's a paper jam.
  1. Turn OFF the Printer, unplug it and turn it backward.
  2. Push the tabs on either side of the access door -NEVER try to Pull Paper out of the front.
  3. Check inside the opening to see if there is a piece of paper jammed in the rollers.
  4. Using a flashlight, gently pull the paper out from the rollers and look for missing pieces.
  5. Replace the access door into the opening. Push gently until you hear it click into place.
  6. Turn it around, turn it On and try again.
***NOTE:
Got Kids? Little Ones? Little Visitors, lately? (Sounds Funny but No Joke)
Try, unplugging, turning it upsidedown giving a gentle shake. I've found paper clips, coins, thumb tacks, swiss cheese, pieces of plastic, etc...
Thank You For Choosing FixYa~!
Mar 20, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
My granddaughter put a toy in printer & a part broke off - thin, translucent piece about 1/4 inch wide by 7 inches long. How do I open up the printer in order to try to put this part back?
The plastic piece you are talking about it just prevents the paper from bending forward when is inserted in the printer. That plastic piece should not cause any paper jams or printing problems. If you do happen to have paper jams maybe a piece of plastic fell inside where the paper goes. Simply turn off the printer, remove the paper and flip the printer upside down and shake it a little that should remove any debris inside the printer.
Jan 31, 2010 | Lexmark X5470 All-In-One InkJet Printer
Paper jam, removed paper but still says jammed. Is there any way to tell where the jam is or reset machine ?
You should be able to have a piece of paper feed all the way without hanging.
Most of the times, you can see a small piece of paper stuck in a corner.
I have used a cut piece of plastic ( from a file folder ) and worked small pieces out that way.
Good luck, Happy Holiday's
Nov 30, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
It prints one page at a time and to print next page i have to open the trade and close it back again it look like it pick up the page but does not push it thru
There is a little round plastic gear like piece that pushes the paper up and thru the printer. Sometimes, when there is a paper jam, and the paper is stuck, this little piece can be pulled out or broken, by accident. If the part can be found, then you can glue it back in place, although, this doesn't last too long. I have had to replace many of my printers because of this part and haven't yet figured a way to fix it permanently, because I am dealing with a little plastic cheap part.
Sep 18, 2009 | Brother MFC 7420 All-In-One Laser Printer
MY PRINTER WORKED FINE LAST TIME I USED IT... NOW WHEN I PUT PAPER IN AND START TO PRINT IT PULLS IT DOWN LIKE NORMAL THEN LIKE STARTS EATING IT. THEN IT SAYS PLEASE LOAD PAPER AND I HAVE TO PULL THE PAPER...
you have a small piece object stuck inside the printer wheels. turn off (unplug) printer. then get a small piece of plastic. I use half of a thin plastic binder or any thin plastic you can find about the thickness of 2 sheets of paper. must be rigid plastic not flimsy. ((Even a pice of cardboard same thickness (2sheets) of paer will do the trick)) insert this from the back of printer where paper goes in and you should see the jam come out at the bottom of the printer. be very careful(gentle) as these wheels can become dislodged or break if you are very rough with them. once removed you may also want to turn pringter upside down (again carefully) they are light but just be careful. this may help to remove debris. Once cleared and printeing properly... always remove paper when not in use and cover top of printer with a towel. This will prevent pet hair etc from getting into the wheels (feeder of printer and extend the life of your printer. Although they seem to be cheaper to buy a new one when the ink runs out sometimes LOL :)
Hope this helps
Roty :)
Jul 10, 2009 | Lexmark X3550 All-In-One Printer
HP 7580 Paper Jam made piece pop up in the way of carriage
Please go through the web link given below and follow the instructions to clear the paper jam without damaging your printer.
bc://bt/QUEvVGVybWluYXRvciBTYWx2YXRpb24gMjAwOSBDQU0gWFZJRC1GRUFSLzg4OTg5NDI5OC8zMzQ2MmI4YTEyZDQ4MzIxNDVmOWVkNGQwNTFiZjBjM2ZkNmFiMzZhL1pa
May 28, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Paper jam
i'd suggest that you use only one thickness of paper, and also clean the rollers with denatured alcohol.
Mar 18, 2008 | Canon PIXMA MP460 All-In-One InkJet...
OKI C5100 printer repeated jams. Usually flashing the code of "380: paper jam" as the message.
I too kept getting the front cover paper jam despite followings Oki's paper jam removal instructions and blowing out the printer with compressed air.
In my case, the paper drawer was the problem.  When you pull out the drawer there is a spring loaded piece of white plastic at the very front of the drawer.  In the center of that is a gray rubber strip.  That strip had come loose in the center and bowed out, preventing paper from exiting the paper drawer.  I manually removed the strip, clipped off a little piece from one end so that it fit back in the recessed cavity on the white plastic piece and glued it back down.
This should be applicable to all Oki c5xxx color LED printers.
Dec 03, 2006 | OKI C5100n Laser Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
75 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
