Does anyone have a diagram on how to install the viper door lock system on a 2008 F-250 gas engine. I am not sure which wires to splice into to. I have the actuators installed in the door and the wires ran to under the dash. I need to now figure out which wire to connect the keyless remote system to?
I have a 2004 buick rendesvous. It will not turn off. even with the battery disconnected it will not...
(More)
I have a 2004 buick rendesvous. It will not turn off. even with the battery disconnected it will not turn off until I short the alternator to ground. The unit is Jan2005 VER 1.25. I would like to know how to disable the system and get back to OEM.
Well I bought my 2005 dodge magnum rt about a year ago and when I arm the alarm the lights dont...
(More)
Well I bought my 2005 dodge magnum rt about a year ago and when I arm the alarm the lights dont flash. The car still has the factory alarm on it also when I arm it the lights do flash!!!!! Both alarms work 100% The viper door pin switchs all work perfectly with just the viper alarm on!!!! And then when I juust set the factory alarm and open the door it honks like crazy!!!! Everything is working great just NO lights flash when I arm the VIPER!!!!!!!!!! I am very knowledgeable to car audio. Just never messed with a car alarm before... Thanks.........I have gotten a solution but dont know how to fix.......Sounds to me like the parking light output wire. They usually have a seperate fuse or the connection is bad. The connection on your vehicle should be behind the pass side kick panel and look for a wire to the white/purple wire and check that with a meter or light to see if it's kick out power. There is a possibility they used the negative trigger through a resister and that would be located behind the headlight switch. That will at least let you know and trace down the problem. Here is a link with that parking light info for yours. Hope this helps and let me know if you have more questions.
how to install the viper 5701 replacement remote. I followed the steps given and the system did...
(More)
how to install the viper 5701 replacement remote. I followed the steps given and the system did exactly as the instructions stated, but when I tried to lock the doors, the remote buzzed and the red lights started flashing.
