Question about ScanSoft PDF Converter Professional (m109a-g00.2.0) for PC
PDF Converter4 I recently purchased PDF Converter4. It seems to have loaded ok, but it doesn't have an .exe file, so the program does not open. (I have uninstalled and reinstalled and gone thru their activation, etc. several times.) I have tried to get some tech. help from nuance, but they want a fee.
I have a mpeg files but i want to convert it into a amv files where i can get a converter?
Posted on Feb 24, 2008
  • 146 Answers
You can try to manually locate the executable file, provided the install was not corrupt, by going to my computer then to the C: drive, then click program files. It may warn you about opening this folder but open it anyway.
Look for a folder with the name associated with the application name (i.e., nuance, ScanSoft, or PDF Converter.). Open that folder and look for the executable file. Once you find it right click on it and click send to, then click desktop(create shortcut).
Go to your desktop and try the shortcut. If it works, you can drag it anywhere you want it. If it doen't start the program go back to the folder and search for another .exe file and repeat the process.
Posted on Jan 06, 2008
How do i put back file mp3 rocket win.exe file
The safest way is to re-install the program.
1. Re-download the installation files here:
MP3 Rocket
2. Uninstall the non-working version.
Uninstall or change program Windows Help
3. Install the re-downloaded version.
4. Open My Computer.
5. Locate the MP3Rocket.exe file. Double-clicking on this file should start the installation for the program.
Jul 23, 2014 | MP3 Rocket
Emachine will not run anything
Rundll32.exe errors typically occur in response to the inability of Windows to access an application, program or file as the result of a corrupted or missing DLL (Dynamic Link Library) file or in response to a rundll32.exe virus that has been designed to look like a normal Windows process.
Here are the easiest ways to fix rundll32.exe errors.
Click "Ctrl + Alt + Delete" on your computer's keyboard to open the Task Manager window.
Click the "Processes" tab and search for a rundll32.exe program.
If one is running and appears to be accessing a lot of your system's resources, click "End Process" as it is likely a malicious program and not a true Windows program.
Run software to seek out, detain and remove viruses, malware, spyware and adware. Often these malicious programs corrupt DLL files or cause them to be deleted or moved and, as mentioned, some rundll32.exe programs may in fact be viruses on your system.
Reboot your computer to update any changes you may have made recently to your files and programs.
Many programs and applications require a reboot for successful installation.
Uninstall a recently installed or changed program or application and then reinstall it using the default settings.
An installed program may not have loaded properly, an installation via the Internet may have been interrupted enough to create errors or the program may have a bug.
If you uninstalled a program and see a rundll32.exe error, reinstall the program and then uninstall once more.
Retain the services of a Microsoft certified technician, if all else fails, to review and fix your system's Registry.
Dec 01, 2013 | E-Machines Computers & Internet
YahooMessenger.exe-Aplication Error The application failed to initialize properly [0xc0150002].Click on OK to terminate the application
Try to remove yahoo messenger and re-install it again.
If you can't uninstall it try this:
1) Log out of Yahoo Messenger and close yahoo messenger completely [ it should not be running under task manager as a process ]. 2) Open Start Menu >> Control Panel. 3) Double-click on Add or Remove Programs. 4) Locate Yahoo Messenger in Add or Remove Programs. 5) Click Change/Remove button. 6) Restart your computer, if it doesn't restart it automatically. 7) Open Yahoo folder in Program Files (C:\Program Files\Yahoo) and delete it. 8) Open registry through Start Menu >> Run and type regedit now navigate to the HKEY_CURRENT_USER\ Software\ registry entry, delete Yahoo, and exit the Registry.
If the above method does not work for you, try the following methods to solve the problem.
1. Open Program Files >> Yahoo Messenger and find the file UNWISE.exe file. Double click this to run it. This will un install yahoo messenger.
Jun 27, 2011 | Yahoo Messenger
Cannot open any programs, keeps asking "chose
Good day. Your correct my friend. Usually if a program that is usually used in a computer then suddenly uninstall, all files that uses that program will show that message your getting because your computer cannot open them . What you need to do is to install the program or software again. For example, if your downloading a file in pdf you need to download adobe reader or if you are download a video file you need to download and install the player like mediaplayer, divx. You just need to make sure what type of file your downloading and you can select the option to check the internet for softwares that can run this file. Hope this information help you a bit. Have a great day
May 26, 2011 | ASUS Computers & Internet
Hi, i am having a problem trying to remoove yohoo messenger from add and remove programs, i get a message.,.could not open install.log file. my computer is now starting to low down.. confussed, ...
1) select Start->Run
2) click Browse button
3) find unwise.exe in Yahoo! install folder (usually C:\Program Files\Yahoo!\Messenger\unwise.exe), click OK in 'Browse' window
4) after that you should see in Run window the following:
"C:\Program Files\Yahoo!\Messenger\unwise.exe"
5) edit this line, so it looks like:
"C:\Program Files\Yahoo!\Messenger\unwise.exe" install.log
(after "the path" put the space and type install.log)
6) click OK in Run window
That should uninstall yahoo messenger.
Mar 11, 2011 | Computers & Internet
On startup I get message:- c:\program
Uninstall the java. Restart the computer. You can't see the message again. But java is important for computer that's why install it again from net.
Thanks.
Feb 04, 2010 | Computers & Internet
I am getting error message for win32 generic host data executor prevention
Here is my resolution to the error
SVCHOST.EXE GENERIC HOST PROCESS OR
DEP ERROR
IT DOES NOT INCLUDE
DISABLING WIA
OR
DISABLING DEP (which is a good security feature)
I have tried it on upto 3-4 computers with success and complete software functionality
Turn the All in One Off
Uninstall the whole of the HP software on the computer
Run a level 4 uninstall
Start --> Run -->X:\Util\CCC\Uninstall L1.bat
Start --> Run -->X:\Util\CCC\Uninstall L2.bat
Start --> Run -->X:\Util\CCC\Uninstall L3.bat
Start --> Run -->X:\Util\CCC\Uninstall L4.bat
Check the computer on the restart
Check if you still get an SVCHOST.EXE GENERIC HOST PROCESS OR
DEP ERROR on restart
Start --> Run
Type in Msconfig
Click OK
Click Launch System Restore
Run System Restore
Create a Restore Point named Hp
Click Start --> Run
Type in Regedit
Click OK
Open Registry Editor
Scroll to the following Registry Key
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentV
ersion\Explorer\
RemoteComputer\NameSpace\2227A280-3AEA-1069-A2DE-08002B30309D
Right click on this Key Click Export
On the Export Registry Window which comes up
Type Hpprinter as the filename and save it on the desktop
Get back to the same Registry Key
Right Click the Key and Click Delete to remove the key
THERE SHOULD BE NO DEP ERRORS THIS TIME
(IF you have any issues after deleting the above key <possibility is remote> restore the computer back to the Hp restore point)
Reinstall the Hp printer Wirelessly or on a wired network now the usual way
Once the software installation finishes
Verify functionality
NOW
Right-Click My Computer, then click Properties.
On the Advanced tab, under Performance, click Settings.
On the Data Execution Prevention tab
Click Turn on DEP for all programs and services except those I select to select the OptOut policy, and then click Add to add the following programs
Create an exception in the DEP for the following programs by browsing to the correct location. The following list outlines the locations:
Hpcmpmgr.exe (x:\Program Files\HP\Hpcoretech\hpcmpmgr.exe)
HPwuSchd2.exe (x:\Program Files\HP\HP Software Update\hpwuSchd2.exe)
HP Digital Imaging Monitor (hpqtra08.exe) (x:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe)
HP Image Zone Fast Start (hpqthb08.exe) (x:\Program Files\HP\Digital Imaging\bin\hpqthb08.exe)
Generic Host Process for Win32(svchost.exe)
(c:\windows\system32\svchost.exe)
Add all these files one by one by browsing to the locations
Click Apply and OK
Let the computer restart if prompted
Its also at times needed to disable
from the Startup of the computer in Msconfig
Hpcmpmgr.exe
HPwuSchd2.exe
The reason is the above mentioned exceptions to the Data Execution Prevention are loaded after the Startup loads and the DEP may try to shut them down at the startup itself and generate the errors
Unchecking the above files does not mean losing any functionality on the All in One all the features should work properly
Jan 21, 2010 | Dell Inspiron 6000 Notebook
We are not able to use any of the programs on the laptop. None of the .exe files are functioning. Tried to run a virus program, can't. Tried to edit regedit, can't. IE seems to be on a clock because it...
First, you have to kill the process that's doing all this.
Hit Ctrl-Alt-Del, choose Task Manager, and look for tasks
install.exe
05643921.exe
Kill them both. Now you should be able to run regedit to remove unwanted entries:
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\uninstall\systemsecurity2009
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\uninstall\systemsecurity2009 displayicon
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\uninstall\systemsecurity2009 displayname
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\uninstall\systemsecurity2009 shortcutpath
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\uninstall\systemsecurity2009 uninstallstring
And then look for the following files on your hard disk (be sure to include system and hidden files):
05643921.exe
install.exe
system security 2009.lnk
system security 2009 support.lnk
There are a couple of variants of this fake security tool, if yours is different, look for strange processes in Task Manager first, kill them and then look for further help.
Dec 20, 2009 | Office Equipment & Supplies
Everytime I use Firefox in any search engine, whether it be Google, Yahoo, or even the one on IMDB, it crashes. With IE and Chrome it works fine. I have disabled all extensions and I still have the same...
You seem to be talking about 2 problems.
1. uninstall and reinstall firefox. If firefox was working ok before a a recent update or plug-in or installed software might be causing the conflict. reinstalling will solve the problem.
Dec 18, 2009 | Mozilla Firefox
Cannot create or open pdf files..using nuance pdf converter4 professional
Try non-professional (free) downloading OpenOffice- you will find you can both create and open pdf files as if Mr. Adobe was sitting next to you...
It works with MS Windows XP if fact the entire suite is totally compatible with MS and other OSs
hope this helps
Apr 22, 2009 | Computers & Internet
ScanSoft PDF Converter Professional (m109a-g00.2.0) for PC Logo
122 people viewed this question
Top ScanSoft Computers & Internet Experts
vsri9
Are you a ScanSoft Computer and Internet Expert? Answer questions, earn points and help others
