Question about Biostar GEFORCE 6100-M9 Motherboard
Cpu fan starts then stops
Pc kept powering down after a few minutes of run time. checked and the cpu fan was not running. rebooted and cpu fan would run for a few seconds the stop.
  • Rusty67 Jan 07, 2008
    I can start the pc from cold and it starts up and the cpu fan runs for a few secomds then shuts down. It's as if the power to the fan plug is being cut. I have run this pc without any problems for 2 years. I'm wondering if the motherboard is at fault as the power supply unit and the cpu fan check out.
I figured it out....... the cheap ass cpu fan went south
Posted on Jan 12, 2008
    Genius:
  • 1,601 Answers
Replace it and let us know if it still happens with the new one.It shut down because of overheating, I hope it didnt mess up your CPU.
Posted on Jan 06, 2008
  • Thomas Christopher
    Thomas Christopher Jan 07, 2008
    The motherboard could have bad caps. Check each one and see if any are bulged on top or leaking.
    Thomas Christopher Jan 10, 2008
    It very well could be the CPU and/or the motherboard.. You said that the cpu fan was not running. It could of overheated the CPU.
    The fan not running would of most likely caused by the bad board. When you get a chance, pull the CPU and see if it is burned. It may have a burn mark right in the middle of the chip.
Dell VOSTRO 460 beeps during startup and will not startup.
many times if the fan over the cpu chip on the motherboard fails to run or blow, an beeping alarm will begin and PC will not start. the cpu has to be kept cool so if fan fails the startup is stopped. have found lose wire connections from fan to motherboard terminal, or power supply may be blown, try checking those first. if nothing lose then wiggle those wires to see if the fan starts.
Jan 30, 2014 | Dell XPS 200 PC Desktop
Thermal shut down on Gateway 500r
Have you checked whether the CPU fan is working or not
Sep 27, 2008 | Gateway 500GR PC Desktop
E Machine T3265 running Windows XP. was running fine until a few weeks ago. Starting turning off Windows (power stayed on) and rebooting on it own. Tried restoring system with restore disks. Kept shutting...
Hello friend,
> You CPU is not problem. ya may be you HDD create bade sector. Sec thing you change HDD data and power cable.
> You fresh new windows Install may be solve you problem.
> One time disconnect all cable attach in PC, and proper reconnect all cable. because if power connector lose then again you PC turn of auto.
More Technical Support call TechSupportMart.
Thanks...
Sep 03, 2013 | E-Machines eMachines Desktop PC
When I plug the unit into power, the CPU fan runs very fast but no boot, and then when I press power on the fan slows down and the PC boots normally. It shuts down in about 30 minutes with no sign of...
Sounds like you are overheating. One way to tell if it's overheating is you say it will run for about 30 minutes then shuts down. When it shuts down try rebooting to see if the boots successfully. If it fails to boot successfully right after it shut down then you are probably overheating. If you wait awhile to let it cool down for 30 minutes or so and if you reboot and it does it successfully you definitely have a overheating problem. If I remember correctly all those compaq sr series have loud and fast running fans. Computers overheat because of three reasons for the most part: 1) A fan has stopped working. 2) The Thermal Paste on the CPU and Heat Sink has dried up or is not thick enough to keep the unit cool. 3) Dust has clogged the fan vents and inside the computer. Fortunately for you desktops don't have to be completely disassembled like laptops to get to the fan, CPU and heatsink. Just pop the case and you'll see the components attached to the motherboard
Mar 18, 2012 | HEWLETT-PACKARD Compaq Presario SR5518F...
CPU fan runs at high speed and won't boot
Change the setting in the BIOS menu. reboot your computer.. when you see the dell logo.. press F1 (or F2 if F1 doesn't work) button until you see the BIOS screen. Check for fan options and change it
Jun 20, 2009 | Dell OptiPlex GX520 PC Desktop
My laptop is freezing for hours at a time.then i shut it down,and retart but it also takes for ever,some times all day is this due to the freezing or is this another problem .and can it also be ovet...
you need do some thing follow:
1) clean the cpu fan and sink(around there dirdy)
2) check the cpu fan is running and stop ok when power on if running go next
3) check the cpu fan, is there any running and stop then see it run again before the laptop freezen?
4) if the fan not running again before freezen that your fan control circuit out of work on the motherboard need to repair
5) if the fan running control ok that the fan can run and stop and run again. you have to add a EXT cooling base under the laptop
hope to help you solve it
May 09, 2009 | Dell Latitude D600 Notebook
Server starts to boot then powers off.
Check your CPU cooler. If it is not properly mounted your CPU/s could be overheating. There is a safety mechanism in Pentium chips that shut down the processor when it reaches a certain temperature. If your heat sinks are mounted correctly, check your Heat sink fans. Ball bearing fans are notorious for making a little noise then quitting.
Jun 10, 2008 | Intel Server Board SE7505VB2 Motherboard
Power of
This happens because your CPU is overheating, open your PC and blow any dust off the openings and CPU/Power supply fans, if you think one of the fans is not working... replace it.
Jan 24, 2008 | Computers & Internet
Biostar GEFORCE 6100-M9 Motherboard Logo
766 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
