ice maker works but either overflows or leaks into the freezer compartment and ice bin making the cubes freeze together. Valve appears to shut off when cycling, and will turn off and not leak when ice lever is moved into off position.
hello, my name is Marclavoris, i will fix your appliance for you.....okay understand that when your icemaker is on, it sends voltage to water valve, if the solenoid in water valve do not close it will fill the icemaker with water..So replace your water valve and your problem is solve...thanks
Was this helpful?
Yes
No
Popular Solutions for GE Side by Side Refrigerator
Refrigerator has warmed up with freezer side at 26 degrees other at 54. Running but not cold. Did...
(More)
Refrigerator has warmed up with freezer side at 26 degrees other at 54. Running but not cold. Did this a month ago but started cooling again after overnight. G.E Profile pss26mstss . Is this a computer board problem? This is a side by side inside the house.
top-freezer refrigerator makes a loud burping/popping sound sporadically - what could it be? It's...
(More)
top-freezer refrigerator makes a loud burping/popping sound sporadically - what could it be? It's fairly old, 15years maybe and a Kenmore
Only 1/2 voltage to compressor. Also, low voltage to light in ice/water compartment in the door -...
(More)
Only 1/2 voltage to compressor. Also, low voltage to light in ice/water compartment in the door - light is very dim. Internal lights and fan work fine.
