Question about Toshiba Satellite A100-S8111TD Notebook
Toshiba satellite m40x
It doesn`t start up. when push the power button it lites for 2-3 seconds and shuts off. it is just a reset problem or something major??
thank you
  • 89 Answers
Do you hear the fan come on? Do you hear the hard drive spin up or notice the hard drive light come on? I relaize it may be a short spurt.
Posted on Jan 06, 2008
How do I unlock my scroll lock on my toshiba m40x
Reboot to access Bios, Select F7 to reset all to default. There is a separate option in Bios to unlock scroll lock.
Oct 16, 2012 | Toshiba Satellite M40X-114 M40X-118...
Reset switch of toshiba satellite M35x
I would definitely Try booting in safe mode to see if it at least loads up the basic system. If it does this then you need to explore what it is that you last installed or did. Hopefully you had a restore point set up but even if not it still is not the end of the world.
But the answer to your question is to press <ctrl> <alt> and <del> all at the same time and this should reboot the system. If it does not you have no choice but to use the power button. If when you push the power button the system doesn't turn off you need to hold it in until the system shuts down. The system will shut down it takes a few seconds (may seem long but it isn't )
When you push the power button and turn the system on start pushing <f8> right at the load screen (you can go ahead and just keep tapping it all the way from the time you turn on the power until it loads the alternative options screen). At the screen select safe mode and see where that gets you.
Good Luck
Sep 07, 2012 | Toshiba Satellite M35X-S114 Notebook
I want to change the CPU fan in my Toshiba Satellite M40X
I found an awesome site
I found the service manual for the Toshiba Satellite M40X in PDF format
You want chapter 4 replacing the cooling module.
http://tim.id.au/laptops/toshiba/satellite%20m40%20tecra%20a4%20dynabook%20vx4.pdf
Nov 10, 2009 | Toshiba Satellite M40-S417TD Notebook
No boot up on my Toshiba Satellite M40X laptop!
try to clean the memory the bronse pin use dry clothes or pencil eraser then put it back, if encounter same error maybe got problem with flex cable come from motherboard go to lcd panel
Aug 17, 2009 | Toshiba Satellite A100-S8111TD Notebook
Toshiba equium m40x won't power up
whats happening is that the cpu is overheating and shutting down the computer due to your fan not spinning, if you wish to test this remove the bottom panel and remove the fan and its cooling tubes should all be one part (quite easy 3 or 4 bolts) and blow on the cpu or put a pedistal fan facing it or any other form of cooling that wont damage it, and try to start it if it boots for a while it is the fan and you will need to replace it, i had this exact problem yesterday
May 18, 2009 | Toshiba A70-S256 Notebook
Manual restart
I assume you have no mouse pointer.
Try pushing the Control/Alt/deletekeys all at once twice to see if that restarts it.
If not, push and hold the power button till it shuts down.
If it doesn't fully restart, then you may have to start it in safe mode. (this is ususlly done by tapping the F8 key as it is starting up)
Let me know how it goes.
Oh, Some of the reset button holes are only small enough for a small paperclip to go into. SO these are sometimes hard to find.
Fran
Oct 21, 2008 | Toshiba Satellite 15" Flat Panel LCD...
Toshiba Satellite Laptop M40X-Z008 RAM STICK INSTALL DIFFICULT
I couldn't find any info on your laptop either. But, I did find contacts for you..
http://www.toshibadirect.com/td/b2c/contactus.to
Jan 01, 2008 | Computers & Internet
Replace toshiba satellite m40x (z008) 60GB toshiba HD with a Samsung HM160JC 160GB HD
both HDs must be either sata or ide and each one must not have a password lock.
good luck
Dec 14, 2007 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
235 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
